text.txt
comemnt if you’re unable to open this link, first time using forms and i’m kinda confused. please help with my build and let me know if all of these parts will build a good computer for gaming, i’m not on a set budget but i wouldn’t like to go much higher than what i’m at right now which is around 1400. please please please help! thank you!
https://linustechtips.com/topic/942151-help-me-with-my-build-please/
I'd highly recommend using PCPartPicker - It allows for checking compatibility, comparing items, and various other things. If you use their "System Build" tab and set one up, you'll get more responses on this forum because it's easier to find problems.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
What you have should support g-sync fine, except that g-sync is pretty unnecessary unless your using a low end machine or a really high end machine. Otherwise i can barely make out your text file(which i virus scanned twice) like everyone else says you should use pcpartpicker some of the links are also broken making it literally impossible to guess whats good and bad.
i’ll get on that PCpart picker right now!
2 hours ago, Christophe Corazza said:
Can you please convert this list into a PCPartPicker list: https://pcpartpicker.com/list/
We'll have a better overview of what you've put together, because now you've simply copy-pasted some URLs into a .txt document.
i’ll get on pcpart picker right now!
These are the list of parts ive made, my friends helped me who say they know what they're talking about but id like some of you to review and help me out.   Will I be able to run most game smoothly with these parts? I mainly play action packed games like RPGs and first person shooters, looking to get into games like rust, day z, etc.
CPU - Intel core 17-8700k LGA1151 (300 series)
motherboard - MSI pro series LGA1151 ddr4 (b250 pc mate)
RAM - corsair vengeance LPX 16gb ddr4 2400
GPU - Nvidia geforce gtx 980 4gb gddr5
hard drive - WD blue 1tb sata 6gb/s 7200rpm 64mb
case - DIYPC X-W-RGB white steel / tempered glass ATX mid tower
power supply - corsair CX500 550w ATX12v 80 plus bronze certified
I have chosen a keyboard, mouse, etc... but I would like some advice on fans, I need 3 for the inside of my case to be sure I won't overheat, also a CPU fan.. I'm not sure which to choose or which are good. I would like them to be more on the quiet side though, also Id like to know if I'm missing anything or if I have everything necessary.
Thanks to all who help, I really appreciate it.
