hello guys so im having problems with my new graphic card every time I try to play games i get a low gpu usage and sometimes the usage spikes to 99 but most of the time the use is between 40 or 50, and this is happening in all games, please help me
my config:
FX 8320E
N68 GS4 FX
2X4GB DDR3 1600
EVGA GTX 970
https://linustechtips.com/topic/941425-low-gpu-usage/
13 minutes ago, Jaburu said:
hello guys so im having problems with my new graphic card every time I try to play games i get a low gpu usage and sometimes the usage spikes to 99 but most of the time the use is between 40 or 50, and this is happening in all games, please help memy config:
FX 8320E
N68 GS4 FX
2X4GB DDR3 1600
EVGA GTX 970
Theres nothing wrong with low gpu usage.... nor spikes.
https://linustechtips.com/topic/941425-low-gpu-usage/#findComment-11476453
2 minutes ago, Jaburu said:
but im getting low fps on games like tomb raider sometimes the fps goes to 25 or 20
Does fps increase when a spike occurs? Also those spikes can be a cause of thermal throttling. Tbh tho just lower your gpu settings if you want more fps.
https://linustechtips.com/topic/941425-low-gpu-usage/#findComment-11476466
It is likely the cpu bottlenecking your gpu. Change some of the more cpu intensive settings to try and reduce it. You can always upgrade the cpu if you want to fix the issue completely but if you don't have the money game settings is the best you can do.
https://linustechtips.com/topic/941425-low-gpu-usage/#findComment-11476472
I would assume it's hardware related. I'm not familiar with amd like that but I'm thinking it's cpu bottleknecking
Firestrike
i7-8700k @5.0GHz w/ 1.30v, Corsair h100iv2, Gigabye Aorus gaming 7, 16GB(8x2) 2666MHz ddr4, Dual RX470's OC'd to 1390mhz(atm) in corssfire - liguid cooled with corsair h60's, 3.25 TB in Samsung SSD's, anidees white crystal cube case
Retired:
i5-4440k @3.2GHz, gigabyte ga-z87x-ud5h z87, 24GB DDR3, 3x1TB Seagate Baracuda HDD.
https://linustechtips.com/topic/941425-low-gpu-usage/#findComment-11476680
You Seriously NEED a better platform, for THAT GPU.
You have 8 cores.
They are LEGIT,. less than Half as fast as Modern CPU's now on Each Core.
Games primarily task 1-4cores of REAL work, and 1-8threads of backup tasking, some games use more, some less...
But the cores of that CPU are still slow, in ANY modern situation, ensuring a bottleneck on the GPU (say using 1440p/4K) still wont help,. because the CPU has those huge dips & sways in performance, which is the problem of your CPU/Ram-subsystem/interconnects,.. not keeping up with the GameClient/GPU demand.
Faster Platform will 100% cure your problem with game performance from your GTX970.
Even an old i5, with each core still being 40+% faster, games will respond kindly.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/941425-low-gpu-usage/#findComment-11479592
But why a Ryzen APU if you already have a GPU? Try to get a 1600/2600 if you can afford it. The 1600 ofen goes on sale.
Main system: Ryzen 5 1600 | ASRock A320M | 8GB 2400MHz DDR4 RAM | GTX 1060 | 1TB WD BLUE
Server: AMD A6-7400K@4.3Ghz | 8GB 1866 DDR3 RAM | 2TB total storage
On the go: Thinkpad E440 | i5 4200M | 8GB DDR3 1600MHz | 500GB HDD
https://linustechtips.com/topic/941425-low-gpu-usage/#findComment-11483517
