so i recently purchased an i5 computer change few hard drives added graphics card and a new power supply  but the odd thing is i flick on the isolator switch on the power supply powers the system on for maybe a second or 2 then shuts off and keeps repeating itself no post and no response from any power switch tried various cpus and power supplys changed memory and still the same thing any ideas
https://linustechtips.com/topic/941370-help-odd-power-anomaly/
You've basically narrowed it down yourself, if you've tried different CPUs, power supplies, and hopefully different outlets then really the only other thing that could be causing it is the GPU or Motherboard. There could be a grounding issue with the way the board is mounted in the case or it could be something else connected to the board but I doubt it. Make sure that you unplug everything else from the board that isn't required for the motherboard to post as you test.
Main PC: Corsair 900D | ProArt Z690-Creator | Intel 13900K | RTX 4090 | Trident Z5 (2x32GB) | 1TB 980 Pro, 2TB Sabrent Rocket 4+, 2TB 980 Pro, 1TB Sabrent Rocket | HX1200i
Capture PC: Meshify XL | Designare TRX40 | AMD 3960X | 2xRTX 4070 TI | Trident Z (4x16GB) | 2TB 970 Evo Plus, 1TB 970 Evo Plus | Dual HDMI 4K Plus LT, 2xElgato 4K 60 Pro, HX850
Media / Render PC: Corsair 900D (shared) | ASRock X399M | AMD 2970WX | RTX 4070 TI | Trident Z (2x16GB) | 2TB Samsung 970 Evo | 2xElgato HD60 Pro | HX750
Full Room Watercooling: EK X3 400 | EK-XTOP Revo Dual D5 | 4xHardware Labs 560GTX | 16xSilentWings 4 Pro  | EVGA 450 B3
Peripherals: Logitech G502 X |  Wooting 60HE | Xbox Elite Controller Series 2 | Logitech G502 Wireless | Logitech MX Keys Mechanical
Displays: Asus XG35VQ | 2xLG 24UD58-B | LG 65UH6030 | Asus VH242H | BenQ GW2480 | HP 22CWA | Kenowa CNC-1080P | Asus VC39H
Audio Interfaces : RME Fireface UFX+, Scarlett 18i20, RME HDSPe RayDAT, RME HDSPe MADI FX, RME ADI-648, RME ADI-192 DD
Audio Playback: 2xYamaha HS5 & Yamaha HS8s | Sennheiser HD820, Sennheiser IE 500 Pro, Ultimate Ears RR CIEMs
https://linustechtips.com/topic/941370-help-odd-power-anomaly/#findComment-11475890
the PC worked before you added hard drives, graphics card and replaced the PSU, right?
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/941370-help-odd-power-anomaly/#findComment-11475897
ive removed the GPU and had the same issue and in a desperate attempt to narrow it down removed it from the case and forgot to plug the 8/4pin cpu power in and still had the same issue seems to be no matter what is in the board or where it is as soon as you turn on the power supply via the switch on the back it just wants to hit a power loop is there any possible way there could be a jumper out of place that could cause this
https://linustechtips.com/topic/941370-help-odd-power-anomaly/#findComment-11475907
The motherboard maybe shorting the Power. Check that there are NO screws under the motherboard. You know what, try the motherboard without the case or External GPU just this: RAM, CPU, Motherboard and PSU. Short the power button pins together. It Should start but if not well it's the motherboard.
EDIT: I meant power not signal xD .
https://linustechtips.com/topic/941370-help-odd-power-anomaly/#findComment-11475912
Reset CMOS.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/941370-help-odd-power-anomaly/#findComment-11475920
1 minute ago, Adamcookie22 said:
as the system sits it is on the motheboard box no GPU 1 memory modual CPU and power supply and still powers on as soon as you flick the switch for the power supply
check if the CMOS pins need to be shorted in order to start
https://linustechtips.com/topic/941370-help-odd-power-anomaly/#findComment-11475933
