How much does 2 power pins and 1 fan make when it comes to overclocking? I just snagged myself a refurbished EVGA SC 1060 6GB for 240 off ebay, I wanted the SSC one I found which has an 8 pin and 2 fans instead of 6-1 but they sold out too fast. I was just wondering how much different 2 pins and 1 fan really makes when it comes to overclocking and cooling. I'm guessing like 5% if even that.
Jesus is the way, the truth, and the life.
Please Quote me when replying.
CPU
 - Ryzen 7 5800X3D | RAM - 32GB DDR4 4000Mhz | MB - MSI B550 A-PRO | Boot - 2TB NVME 980 Evo Plus | GPU - EVGA FTW3 RTX 3090 24GB
https://linustechtips.com/topic/940364-how-much-does-it-matter/
19 minutes ago, WereCat said:
It doesent really make a difference on a 1060
I'm glad. I had a 1050 ti with no plug and it freaking sucked, dam card was always begging for more power, I know its made for lightweight gaming but they really should put 6 pins on those cards. Even not overclocked the card still gives you voltage and power limit warnings while gaming.
CPU
https://linustechtips.com/topic/940364-how-much-does-it-matter/#findComment-11467400
1050ti can use more than 75W which is provided by the PCI-e so it definitely cant run at its best when its limited like this.
1060 is fine with single 6-pin, same for 1050ti.
https://linustechtips.com/topic/940364-how-much-does-it-matter/#findComment-11467448
2 hours ago, Pip313 said:
I’ve never, not once, ever had a power warning on either of my 1050ti’s while gaming in computers with 240w poser supplies and pci-e slots that claim to be only 35w...
what application is giving you the warning?
MSI afterburner/riva tuner OSD. I use it while gaming and I had those 2 limiters to pop up when the limit was reached. Even after I reset my PC and drivers to stock settings the card still bickered at me. It's fine though I wanted an upgrade anyway, the 1050 ti is not a bad little card at all but I wanted a bit more power.
CPU
https://linustechtips.com/topic/940364-how-much-does-it-matter/#findComment-11467808
