Hi guys, I have purchased an ASUS ROG Strix Scar GL703G-ME5029T with "144 Hz Display and G-sync available" which was told by the manufacturer. When I was about to set up G-sync at Nvidea control panel and I realised that the G-sync set up button was missing and i couldn't find any solution to this despite having the latest Nvidea driver. Can anyone help me out thanks ><  Much appreciated.
https://linustechtips.com/topic/939852-need-help-to-enable-g-sync-feature/
what card, what interface ?
Are you sure the model you get has the high refresh rate option?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
Hi there, I'm not sure about it since i can barely get any information about this model for G-sync option and refresh rate. There is a similar model which is GL703GM-DS74 version but it only comes with 120Hz refresh rate display where as mine comes with 144Hz
In my Nvidia Control Panel I have another option/menu available called "Set up G-Sync" that sits between "Adjust desktop size and position" and "Set up multiple displays". Here is an example from Nvidia's website:
nvidia-gsync-nvcpl-configuration-windowe
If that isn't there, I would assume that something isn't G-Sync capable or G-Sync isn't enabled. (I'm unsure how to manually enable it)
Stop and think a second, something is more than nothing.
My set up G-sync feature is missing despite having the latest Nvidea driver. Is it probably misadvertised by the retailer because not one but a lot of them also advertising G-sync available for this model >< ( one of their listing https://www.lazada.com.my/products/asus-rog-gl703g-me5029t-gaming-laptop-i7-8750h8gb-d41tb256gbnvd-gtx1060-6gb173fhdw10-scar-edition-i351730801-s496527393.html?spm=a2o4k.searchlist.list.17.5a926735WH32iM&search=1 )
show exact specs of your laptop
Try clean install Windows
Desktop specs:
