Greetings! My name is Energize (You can call me Liam), and im in the works of buying a brand new pc from scratch.
I'm not 100% Informed as to wich parts are good and bad, wich is the best bang for my buck, ...
So hopefully I can find some help here! :D
1. Budget & Location
I live in Belgium so we use € over here, hopefully that doesnt mess you guys up too hard ^^
I have a budget of a Maximum of around €2000, I can push to €2100 if needed though. (Lower is always better ofcours)
So yeah, big build coming up hopefully :D
2. Aim
This pc is going to serve as a gaming pc (As well as programming, Im 18 and just recently started my programming education),
Wich games? I play games from very hard to run to not hard to run at all so: Battlefield 1, ARK: Survival evolved & The witcher 3 All the way to fortnite, yes fortnite (I can feel the hate coming).
Also what is very important to me is that it turns out to be a pc I wont have to upgrade/replace any time soon.
3. Monitors
Currently it would only have to run 1 monitor, but that is 100% going to be changed to 2 (1980x1080 resolution)
Im thinking about getting a 144hz, but i'm not quite sure yet (probably not)
4. Peripherals
As talked about earlier, I am going to be getting a second monitor, also Windows 10.
5. Why are you upgrading
My trusty ol' pc I got here has seen it's best days, it is completely unable to run high performance games anymore, even at low graphics.
______________________________________________________________________________________________________________
What did I have in mind?
Please help me out on this, i'm far from the most smartest person when it comes to pc building & getting the most for the least price.
Processor
I was thinking about Intel i7-7700k or i7-8700k, opinions?
Motherboard
THIS is the part I really have no clue about what to get, I have 0 knowledge on wich motherboards are best, PLEASE help me out :D
Cooler
Also no idea on this one simply because I don't know wich one would be better to get, water cooling or air cooling, tips?
RAM
16 GB DDR4 - 3200 Corsair vengeance
Graphics card
1070 - 1080ti Somewhere along those lines
HDD & SSD
1TB of HDD (Wich one should I get? I yet again dont have a clue)
256GB of SSD maybe 500 if possible but probably not
Now I think I would like to get the M2 SSD, I don't really know the difference nor the difference in price, I just heard that the M2 is faster and it wouldn't really be worth buying
non-M2 SSD anymore. Again, wich brand?
Case
Couldn't care less, compatible & cheap would be the best
Power supply
Wichever is compatible I guess? I don't know if any brand is better than the other and also don't know how much power I would need for this build.
OS
Windows 10
Conclusion
Where can I/do I need to make cuts, where can I improve?
Also notice I didn't put anything AMD in because I know even less about AMD ;)
THANKS for taking the time to help me out if you do so!!!
https://linustechtips.com/topic/939265-help-with-my-build-d/
I would suggest something like this:
https://be.pcpartpicker.com/list/DbhkD2
I know from experience that certain Belgian computer stores are crap when it comes to pricing.
Therefore, depending on where you intend to buy the parts, prices may vary slightly.
https://linustechtips.com/topic/939265-help-with-my-build-d/#findComment-11456901
PCPartPicker part list: https://be.pcpartpicker.com/list/6JY9KB
Price breakdown by merchant: https://be.pcpartpicker.com/list/6JY9KB/by_merchant/
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  (€372.95 @ Bytes At Work)
CPU Cooler: Noctua - NH-D15 82.5 CFM CPU Cooler  (€89.90 @ Paradigit)
Motherboard: Asus - ROG STRIX Z370-G GAMING (WI-FI AC) Micro ATX LGA1151 Motherboard
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3200 Memory  (€205.95 @ Bytes At Work)
Storage: Samsung - 970 Evo 250GB M.2-2280 Solid State Drive  (€108.95 @ Bytes At Work)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (€66.90 @ Paradigit)
Video Card: Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING Video Card
Case: NZXT - H440 (White/Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Operating System: Microsoft - Windows 10 Home OEM 64-bit
Total: €844
https://linustechtips.com/topic/939265-help-with-my-build-d/#findComment-11457555
