Hey guys,
Im having trouble with my 3TB Seagate Barracuda ...
It started beeping weirdly and not showing up in windows...
Here is the drived hooked up to a external enclosure so you can hear it...
It spins up.. and the heads seem to be in place and not stuck... any ideas?
Thanks
https://linustechtips.com/topic/939212-hard-drive-troubles/
Did you actually open the hard drive? Because now it's basically done for unless the room is basically a clean room on par with CDC's labs. You're not supposed to open hard drives because if any particulate gets on the platter, there's a very good chance it'll cause a head crash.
https://linustechtips.com/topic/939212-hard-drive-troubles/#findComment-11456257
By opening the hard drive, there's a very good chance that you killed it...
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/939212-hard-drive-troubles/#findComment-11456266
3 minutes ago, Antwan said:
Sounds the same... i briefly opened it to see if the head is not stuck as this comes up in every youtube video.
I don't care about the drive... i need the data.
And did those very YouTube videos make a warning about opening the drives? Because if they didn't, those aren't very useful videos.
The thing is that the head on a hard drive when it's fired up is floating on a cushion of air on the scale of literally nanometers. Coupled with the fact that the outer edges of the disk can be spinning upwards of 65 miles per hour, should the head hit a dust particle, it'll basically either ruin the head or cause the head to jump up and crash on the platter, ruining whatever data on the platter where the head scrapes.
If you really need that data, at this point, it's best to take it to a data recovery service than to do it yourself.
https://linustechtips.com/topic/939212-hard-drive-troubles/#findComment-11456299
You should understand that if the drive is dead, it will be very hard to retrieve the data.
Opening the drive, even for a brief second, introduces airborne particles inside the HDD case. This is basically the worst thing you can do to a HDD.
https://linustechtips.com/topic/939212-hard-drive-troubles/#findComment-11456302
28 minutes ago, Christophe Corazza said:
I suggest to carefully close the drive and bring it to a data recovery service.
Closing it now is" crying over spilt milk".
With drive's insides already contaminated if data recovery service tries to run it first there's now risk of certain data loss.
So data recovery service should be informed that drive's been opened and really that should be written onto tape/sticker put on drive's case to make double sure of that.
I'm sure they can clean platters from airborne particle contamination, but that's certainly going to cost extra.
https://linustechtips.com/topic/939212-hard-drive-troubles/#findComment-11456466
I know that "closing" the drive won't help improving the situation.
However, it can prevent the situation from getting even worse: e.g. some hard object falling onto the platters
https://linustechtips.com/topic/939212-hard-drive-troubles/#findComment-11456510
