So after doing the memtest I found these errors on the midway
Are these errors all related to ram or cpu too as it says cpu 0,1,2,3
I am using one 8gb ram only
My cpu is i5 8400 as you can see in the pic but those l1 ,l2 and l3 cache organisation seems a bit doubtful,are they ok?
https://linustechtips.com/topic/937806-memtest-errors-and-cpu/
23 minutes ago, WereCat said:
You seem to run the test with all 6 cores at once. That usually throws errors even if it can be fine.
Try with one core at a time for longer.
Ok i will try one core too, i was getting bsod's often so used memtest, it stopped itself after  10,000+ errors
https://linustechtips.com/topic/937806-memtest-errors-and-cpu/#findComment-11444189
