Hi, so im having some latency issues with my i7 4790k https://imgur.com/dV1qxyl .  I suspect the issue has to do with the intergrated graphics, as when I try to bench test my i7 4790k, it shows a much lower latency (using cpuz to benchmark/intel extreme tuning ulitity).  However when I try to benchmark the integrated graphics card (intel HD graphics 4600) using Intel's extreme tuning utility, all I get is a "The Graphics Stress Test Failed".  https://imgur.com/ZdnwLWX.  Any chance does anyone know of any ways to get this back to working condition? Or do I simply have to live with it till I can purchase a new cpu/mobo/ram?  (I've already tried multiple os's, drivers, etc)
https://linustechtips.com/topic/937443-i7-4790k-problems/
So disable the iGPU and use your dGPU instead? You're more likely to need a new CPU than a new board if the iGPU is faulty.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/937443-i7-4790k-problems/#findComment-11440777
Would I have to go into my bios to disable my iGPU? and the reason im relying so heavily on my cpu is because I currently don't have a dgpu :/.  I was just thinking, if im upgrading my cpu anyways, id probably need to upgrade my motherboard to support it, as newer cpus require the LGA 1551 vs currently my i7 4790k which uses the LGA 1150.
https://linustechtips.com/topic/937443-i7-4790k-problems/#findComment-11440792
1 minute ago, Mikotox said:
Would I have to go into my bios to disable my iGPU? and the reason im relying so heavily on my cpu is because I currently don't have a dgpu :/.  (I was just thinking, if im upgrading my cpu anyways, id probably need to upgrade my motherboard so support it, as newer cpus require the LGA 1551 vs currently my i7 4790k uses the LGA 1150.
Yeah you'd have to disable it in the BIOS, but if you don't have a dGPU you obviously can't do this. If you upgrade, you'd need to buy a new CPU, new RAM (DDR4) and a new board, yes.
https://linustechtips.com/topic/937443-i7-4790k-problems/#findComment-11440799
1 minute ago, firelighter487 said:
does the iGPU still work? or is it just the stress test that fails...
it craps the bed when I try stress testing it.  It works, but it stutters and has a ton of latency issues to the point where its basically unusable (sound/video issues).
https://linustechtips.com/topic/937443-i7-4790k-problems/#findComment-11440800
Ya.... that was what I think Ill probably have to do.... I've already tried swapping the psu/ram/motherboard and those weren't the issue, so the only thing left that I haven't touched is my cpu.... but thats going to require a new mobo/DDR4 ram *cries*
https://linustechtips.com/topic/937443-i7-4790k-problems/#findComment-11440802
Any chance would the "oven trick" fix my cpu? or is that just wishful thinking?
https://linustechtips.com/topic/937443-i7-4790k-problems/#findComment-11440807
Nope. The iGPU is on the die of the chip. You can't fix the die by baking it. Baking is just for temporarily fixing solder joints.
https://linustechtips.com/topic/937443-i7-4790k-problems/#findComment-11440814
IGPU probably shat the bed, if you did any overclocking of it that's probably why. Just use a dedicated graphics car tho because the IGPU is pretty shit anyway while the CPU is still awesome
Builds:
https://linustechtips.com/topic/937443-i7-4790k-problems/#findComment-11440846
you can try using this progam https://downloadcenter.intel.com/es/download/19792/Intel-Processor-Diagnostic-Tool
if there is a another problem  you will see. buy used gpu  if your cpu is working you can keep until you upgrade to another system
 you should check all bios option from the igpu
https://linustechtips.com/topic/937443-i7-4790k-problems/#findComment-11441086
Are you actually using it? A monitor is currently plugged in and outputting video?
What problem exactly are you getting to point to the igpu?
https://linustechtips.com/topic/937443-i7-4790k-problems/#findComment-11443169
Yes, a monitor is plugged it.  Whenever I run a stress test on the cpu, the latency disappears, and each and every single time I try to test the igpu it fails, no matter what stress test application im using, no matter what OS im using.  I've already tried swapping out the mobo/psu/ram, so the only thing left that could possibly be the issue is the igpu.  Quite frankly, i've already tried everything I could think of, and the only thing that could possibly be the issue is the CPU/IGPU.  No amount of reinstalling drivers/changing OS/reinstalling OS/checking wires, will fix my issue.
https://linustechtips.com/topic/937443-i7-4790k-problems/#findComment-11443443
I’m asking what the actual issue is? What problems are you having real world?
https://linustechtips.com/topic/937443-i7-4790k-problems/#findComment-11443516
