So a few days ago i got a i5 8400 with a GIGABYTE B360 HD3 but don't know what memory to get. Mainly i'll be using this system for gaming and someone on the forums suggested that i should get a single 8GB stick but most CL i see on shopping websites are 16-19. Is that acceptable for gaming i should go for something like 3000MHz with CL15-16?
https://linustechtips.com/topic/937160-memory-advice/
well nowadays for gaming + youtube you are reaching 6gb or more so depending your needs you could easily reach 8 gb, if you dont have budget now for 16gb buy 1 stick of 8gb. Gaming and ram timing doesnt affect very much. Having poor timings might affect the load times, but it is unlikely to be the sole cause of stutter.
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
https://linustechtips.com/topic/937160-memory-advice/#findComment-11438327
Well it intel  so say go with 2133 mhz no need to go so high unless your getting it at good price.  If it was ryzen cpu then yea  3000mhz will help you. I would say go with 2 x 8 kit. I am upgrading a lot general pc to 8 GB because of modern programs.
https://linustechtips.com/topic/937160-memory-advice/#findComment-11438340
Your mobo only supports up to 2666 MHz so 3000 mhz is a waste of money.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/937160-memory-advice/#findComment-11438396
There are many misconceptions here, first of which being that 3000MHz RAM cannot run on a motherboard/CPU that only supports 2666MHz. This is the official supported max for consumer Coffee Lake chips, but many people run all the way up to 4133MHz RAM on combinations somewhat similar to this. It technically isn’t supported, but a few clicks in your BIOS will bring it up to speed in an instant. However, the speed of memory also isn’t important when it comes to gaming and many everyday tasks. Only minor gains are noticed when using very heavy workloads (e.g. CAD software). I had 2x8GB sticks at 3000MHz on my previous SkyLake build, but 2400MHz will work just as well for you. Finally, get 2 sticks to add up to your total, 2x4GB or 2x8GB, because your CPU can take advantage of dual-channel memory which effective doubles your speed. I recommend G.Skill Ripjaws V at 2400MHz, get 16GBs if you can for improvements of other things in your system in the future. 16GB is also recommended for many intensive AAA titles, especially these new games announced at E3. Hope it helps!
Desktop: Intel i7-8086K, Asus ROG Maximus X Code (probably, still can’t decide), NZXT Kraken X62 280mm, Asus ROG Strix 1080 Ti, G.Skill Ripjaws V 16GB (2 x 8GB) 3000MHz, Corsair CX750M PSU, be quiet! Dark Base Pro 900 Inverted, Samsung 960 Pro M.2 PCIe 500GB SSD, Samsung 850 Evo SATA 250GB SSD, WD Black 1TB HDD.
Laptop: Coming Soon
Peripherals: Razer Deathadder Elite Chroma, Razer Ornata Chroma, HyperX Cloud II Headset, Corsair Very-Large Mouse Mat
https://linustechtips.com/topic/937160-memory-advice/#findComment-11438475
Also, lower CL is better, but still not very noticeable. Go with a slightly cheaper model that is maybe CL16 instead of CL14 or CL15, and spend the money elsewhere in the system.
Laptop: Coming Soon
https://linustechtips.com/topic/937160-memory-advice/#findComment-11438486
Was thinking to get a 8GB stick now since the prices for a 16GB kit is way over 200Euro's and upgrade later to 16GB of RAM
https://linustechtips.com/topic/937160-memory-advice/#findComment-11438510
Then get 2 4GB sticks, it will double effective speed.
Laptop: Coming Soon
https://linustechtips.com/topic/937160-memory-advice/#findComment-11438528
You can always get 2 more 4GB sticks later. It will help now, and RAM prices probably won’t go down for a while. Newegg does have occasional deals though. Not sure if it exists in Europe, but it’s great in California.
Laptop: Coming Soon
https://linustechtips.com/topic/937160-memory-advice/#findComment-11438533
When he says spend it elsewhere in your system, he means buy an SSD.  :) (or I think he means that)
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/937160-memory-advice/#findComment-11438583
