I currently have custom loop and it was a blast building but I am not liking my case alot (Antec eleven hundred). But I cant decide what case I would rather get between the Mountain Mods H2gO and the Caselabs S5 (which will hopefully be release within a month). I want a case that is fairly portable so I can easily take it back in forth from college. Now the H2gO is an older case which is kind of making me debate on whether or not I should go for it. While with the Caselabs would be a much more expensive option because not only would I have to spend more than likely $300+ for the case but I would also have to purchase a mATX mobo also which would be $120+. While if I get the H2gO it would be around $250 and I could use use my current motherboard. But with the Caselabs case you get the amazing quality and modularity of a Caselabs case. So now that I have kind of listed the pros and cons which would you go for? Thanks
https://linustechtips.com/topic/9358-debating-on-cases-need-others-thoughts/
i would go for caselabs and the H2go is really hard to work with caselabs cases make mm cases look like kids toys
This is what i was thinking. Caselabs quality is second to none, but i dont know if the cost difference justifies it. :P
Have u looked at Nanoxia Deep Silence 2 it seams like a good case for u as it portable and fits atx motherboards plus good water cooling options for the case
This seems like a descent case but 2 things. I cant seem to find where to buy it any place or on their website. Also 2 things I dont really like about it is that it does not have a window nor does it have the horizontally mounted motherboard tray that I am a big fan of.
