Pc component help!
Go to solution Solved by NelizMastr,
10 minutes ago, Martii said:
This is 1080 720p low settings.
I ran it on Ungine BENCHMARKING software
And MSI Afterburner to check my cpu usage and gpu usage
Bro, take the cable out of your motherboard and plug it into your GTX1060 please. You're running on your CPUs internal graphics ;)
For the past few weeks;
My computer seems to fail me in games.
I did a benchmark on it and found the most disappointing result.
Current Build;
OS: Windows 10 Home (64 bit)
CPU:Intel Core i5 6600 @ 3.30GHz (Skylake 14nm Technology)
RAM: 16.0GB Dual-Channel Unknown @ 1064MHz (15-15-15-36)
Motherboard: ASUSTeK COMPUTER INC. H170 PRO GAMING (LGA1151)
GPU: 2047MB NVIDIA GeForce GTX 1060 6GB (NVIDIA) (SLI Disabled)
HDD: 931GB Western Digital WDC WD10EZEX-08WN4A0 (SATA)
Monitor/s: ASUS VC239 (1920x1080@60Hz)
https://linustechtips.com/topic/935535-pc-component-help/
GPU1 and GPU2? Are you using integrated GPU?
Also, 2GB 1060? What kind of 1060 is that?
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/935535-pc-component-help/#findComment-11423948
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/935535-pc-component-help/#findComment-11423962
2 minutes ago, Martii said:
How do I do that? I don't have the proper guidance to do these kinds of stuff haha.
You video cable. Plug it in directly to your graphics card. It looks like your plugged into your motherboard.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/935535-pc-component-help/#findComment-11424012
There's a cable going from your monitor to your PC. That cable needs to be removed from the port on the motherboard I/O shield and moved down to the videocard, which is in the expansion area underneath.
https://linustechtips.com/topic/935535-pc-component-help/#findComment-11424021
Oh you mean the cable going from my monitor to the pc should be on my gpu rather than the motherboard?
https://linustechtips.com/topic/935535-pc-component-help/#findComment-11424041
On 6/8/2018 at 5:22 PM, Martii said:
I have dual monitors; maybe that's why I placed it there.
I have a 2nd wire too.
Your primary display should always connect to the GPU, otherwise, it'll use your integrated graphics.
https://linustechtips.com/topic/935535-pc-component-help/#findComment-11431473
