Return to Top
Go to solution Solved by GoldenLag,
Just now, Tekred said:
Nah the home button takes you to the home page, Im suggesting a "return to top" button that takes you to the top of the page you're viewing. I've seen it on other forums before and it was a nice feature
im talking about the keyboard keys. not on the website itself. the  "end" key, the "home" key and "pg up/down" keys can be used to navigate the website instead of scrolling.
So not sure if its a thing already and I'm just blind, but having a return to top button at the bottom of the page would be wonderful. Some of these posts get pretty long and instead of having to scroll for days to reach the top we could just hit the return to top button. If its already a thing could someone help me out lol.
https://linustechtips.com/topic/935489-return-to-top/
on pc you can hit the "end" key to get to the bottom and "home" key to get to the top. ive got no solution for android or IOS, but im certain there is a way
https://linustechtips.com/topic/935489-return-to-top/#findComment-11423425
https://linustechtips.com/topic/935489-return-to-top/#findComment-11423436
https://linustechtips.com/topic/935489-return-to-top/#findComment-11423442
This is something that gets suggested from time to time, and that I will be considering in the next update (where considering does not mean that it will definitely happen). The home and end keys are usually the best option, but a surprising number of people don't know about them, and they don't exist on mobile.
HTTP/2 203
https://linustechtips.com/topic/935489-return-to-top/#findComment-11423665
Thanks, yeah im usually on mobile so that's why I started this and I didn't even think about the home and end keys on the keyboard. A few other forums has a "top" button and comes in very handy while viewing on mobile
https://linustechtips.com/topic/935489-return-to-top/#findComment-11423677
Out of interest, what forums in particular?
HTTP/2 203
https://linustechtips.com/topic/935489-return-to-top/#findComment-11423756
