1. There's extra video compression for video over 8K resolution
2. 10k resolution with 16:9 aspect ratio should never be 7760 pixels wide, you screwed up your math.
Desktop benching:
https://linustechtips.com/topic/935068-10k-how-does-it-work/#findComment-11419635
9 minutes ago, aandril said:
2x 2.66 is still under 9. You'd need 4 cables...
Then some form of compression or chroma subsampling. 4:2:0 requires half the bandwidth as 4:4:4, but is fairly transparent for consuming content.
EDIT: according to Wikipedia, "HDMI 2.1 specified a new 48G cable which supports a bandwidth of 48 Gbit/s and Display Stream Compression (DSC) 1.2 is used for video that is higher than 8K resolution with 4:2:0 chroma subsampling." Uncompressed 10k will require multiple cables with current standards.
https://linustechtips.com/topic/935068-10k-how-does-it-work/#findComment-11419636
1. By What, 10%?
2. So even if It's 10000x5600 it's still 56,000,000. 56mil/8.6mil= 6.5
10% taken off 6.5 leaves 5.9 which is still more than 2.66.
https://linustechtips.com/topic/935068-10k-how-does-it-work/#findComment-11419661
Technically then, 2.1 doesn't support 10k... sigh.
https://linustechtips.com/topic/935068-10k-how-does-it-work/#findComment-11419665
2 hours ago, aandril said:
4K 4096x2160 = 8,847,360
10K 10328x7760 = 80,145,280
80,145,280/8,847,360= 9.058666088
HDMI 2.0 about 18Gbps
HDMI 2.1 48Gbps
48/18= 2.666
HDMI 2.1 supports 2.66 times the bandwidth, but 10K is 9.05 the times as 4K resolution.
WUT? How does that work?
1. When HDMI 2.1 says 10K they are referring to 10240×4320 (≈21:9), which is 5.33x as many pixels as 3840×2160.
2. The data rate of HDMI 2.1 is 3x compared to HDMI 2.0 due to more efficient use of bandwidth, not 2.66x. HDMI 2.0 is 80% efficient (14.4 Gbit/s out of 18 Gbit/s usable), and HDMI 2.1 is 88.8% efficient (42.66 Gbit/s out of 48 Gbit/s), 2.96x the data rate.
3. HDMI 2.1 supports 10K at up to 120 Hz only using Display Stream Compression (DSC) or chroma subsampling, not uncompressed/4:4:4.
https://linustechtips.com/main/topic/729232-guide-to-display-cables-adapters-v2/?section=calc&H=10240&V=4320&F=120&format=ycbcr422&compression=dsc3.0x
https://linustechtips.com/topic/935068-10k-how-does-it-work/#findComment-11419678
