Hey my chair has really been annoying me recently so i've been looking into getting a new chair.
Requirments:
140 dollars max
Not leather because I have had 3 chairs and they all peeled.
Not a bright color, black/brown would be fine.
Not a gamer racing chair. They look really cool, but I don't find them comfortable.
Height adjustment, and on wheels
Possibly tilt adjustment for the back which can be locked into place. If this is not possible, at least tilt adjustment with both the seat and back.
Long armrests
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/935021-help-finding-chair/
How tall are you, how much do you weigh. im 6'2 180 and i cannot use the same chair my friend whos 5'7 because of the way the chair is designed better for shorter peps.
https://linustechtips.com/topic/935021-help-finding-chair/#findComment-11419172
6 foot 3 but im 14 so I can still grow a bit more so yeah. I weight 175.
My Rig
 Peripherals
https://linustechtips.com/topic/935021-help-finding-chair/#findComment-11419199
I would get the biggest chair you can find from wherever then, because you very well may end up being being taller. Weight probably wont be an issue, Tall people chairs tend to also be "big" people chairs and should support up to 300 lbs easily, not that you should ever weigh that much :P
https://linustechtips.com/topic/935021-help-finding-chair/#findComment-11422391
