OK So when I stress test my CPU my CPU gets to about 70-80°C but the water stays at 36°C. I'm not sure why it's not increasing with my CPU.
I'm not sure if my cooler is actually doing anything.
5820K @4.5 1.325V
H100I GTX
MSI X99A Krait
Main Rig | I9-9900K @ All Core 5.3 1.37V | Asus 2080TI | NZXT X72 | SM951 256GB | Samsung 850 Pro 500GB | Seagate 2TB | Corsair Vengeance RGB 32GB 3200MHz | RM850I | Corsair 570X
Ether Server | 2x Xeon E5-2660 | Supermicro X9DR3-F | Deepcool MATREXX 55 | 128GB Toshiba THNSNJ128GCS | 2x WD 4TB Red | ECC 64GB Samsung 1RX4 PC3L-12800R
https://linustechtips.com/topic/934161-h100i-gtx-cooling/
Bad mount. If the cpu was idle, a dead pump still wouldn’t be that hot.
https://linustechtips.com/topic/934161-h100i-gtx-cooling/#findComment-11410200
5820K @4.5 1.325V
H100I GTX
MSI X99A Krait
It could indeed be a bad mount or a problem with the thermal paste.
Try the following steps:
- remove the cooler
- whipe the old thermal paste using a fibre cloth (and perhaps some isopropyl alcohol)
- inspect both surfaces (cooler and CPU) for irregularities... for example: removed any plastic foil?
- reapply new thermal paste
- remount the cooler
Hope this helps
https://linustechtips.com/topic/934161-h100i-gtx-cooling/#findComment-11411520
5820K @4.5 1.325V
H100I GTX
MSI X99A Krait
The water temp will always be less than the core temp but if you getting such a large difference and also have high idle temps then it's most likely a bad mount as the others have mentioned. Also to note you want to ensure the AIO get full 12V power do not set any fan curves on the pump at all.
https://linustechtips.com/topic/934161-h100i-gtx-cooling/#findComment-11411708
