idk what else do you want it to do
Desktop benching:
https://linustechtips.com/topic/933481-help/#findComment-11403969
There's only a small handful of things you can check yourself. Boot drive, RAM, Wi-Fi card...not much else. If almost anything else is wrong you'll have to take it up with a repair shop or the manufacturer.
Can you recall any incidents occurring? Dropping it. Sitting on it. Liquid. Etc...
https://linustechtips.com/topic/933481-help/#findComment-11403999
8 minutes ago, Tasi3gaming said:
I want to repair it because thats my main pc
manufacturer RMA or repair shop. Laptops are difficult to fix by yourself
Desktop benching:
https://linustechtips.com/topic/933481-help/#findComment-11404008
Sadly i cant check the ram,Boot drive... because there soldered on the board
And there were no incidents.
https://linustechtips.com/topic/933481-help/#findComment-11404017
When you say it does nothing, do you mean that there is no display?  Does it have a HDD activity light, is it flashing which might indicate that it is loading windows but you just can't see it on the display.  Can you connect it  to another monitor or to your tv to see if it is just your display screen?
https://linustechtips.com/topic/933481-help/#findComment-11404048
Jesus. Was this manufactured by Microsoft? So even Microsoft is going the Apple route? (or vise vera) This is bullshit. It's time techies buy a hot air rework station and source our own chips. We need to take back our ability to fix out own shit.
https://linustechtips.com/topic/933481-help/#findComment-11404110
I had connected a tv to it and it did not do anything and the laptop does not have a hdd activity led
https://linustechtips.com/topic/933481-help/#findComment-11404312
