I need help planning my next upgrade
You may get quite an improvement when upgrading your CPU to an i7, but I would check other things first. Check if there are any miners or other malware on your PC. Update GPU drivers. Try overclocking your CPU. Faster RAM may help a little bit because 2133MHz is quite slow, but I am not sure if RAM speed affects Intel as much as it affects AMD Ryzen CPUs. Try updating network drivers, especially if you use a non-Intel NIC, as sometimes these NICs offload processing onto the CPU, which Intel NICs usually have processors onboard that do most of the heavy work.
A 6600K doesn't seem like it should bottleneck too bad at all, but if you determine that it is causing your low FPS issues, then I would just throw a 7700K in and call it a day. Maybe a Coffee Lake CPU if you have more to spend but then you need a new motherboard.
