I recently added DIY air filters to my very tiny 80mm itx case as, In a recent check of my system, I found it filled with heavy amounts of dust particles. Now, the temps are slightly higher than before. On heavy usage, they go near 70ish which was never the case before the filters. And, HDD/SSD/RAM are constantly between 46c-54c. Should I remove the filters and give the mobo alcohol bath every 2-3 weeks?
Room temperature: 33-35c
Cpu: i5 7500
Main system (Mini itx 80mm)
i5-7500 | Asrock h110m | Noctua L9i | Realan H80 Case | 8GB 2400 Ram ADATA | M600 SSD | 500 GB Seagate
Other System (Laptop)
i7 3632QM | Toshiba | 8GB Corsair VS RAM | Sandisk SSD PLUS | 500GB Toshiba HDD
https://linustechtips.com/topic/932920-are-these-normal-temps/
All those temps are perfectly healthy. Wouldn't worry about it.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
https://linustechtips.com/topic/932920-are-these-normal-temps/#findComment-11398830
The CPU is fine, but not so much the storage drives. Below 40C is optimal for their lifespan.
Desktop benching:
https://linustechtips.com/topic/932920-are-these-normal-temps/#findComment-11398833
My case has very minimal airflow. How can I reduce those temps? Is dust more dangerous here or temps?
https://linustechtips.com/topic/932920-are-these-normal-temps/#findComment-11398840
Both are actually detrimental for electronics.
To keep dust out of your computer, it is often recommended to make sure the pressure inside your case is higher than outside.
More practically, this means that you should have more air blowing in that air blowing out of the case.
https://linustechtips.com/topic/932920-are-these-normal-temps/#findComment-11398852
Add more fans/use those that spin faster.
Having dust is better than having parts run hot. Cleaning can help the former but not the latter
Desktop benching:
https://linustechtips.com/topic/932920-are-these-normal-temps/#findComment-11398867
When I was building my PC externally, or on the motherboard box, I had a single 120mm fan, and decided to direct fan at the SSD. The SSD reached a top of 27, averaging around 22-24. More fans inside your case, the better. The more cleaning though.
hi.
https://linustechtips.com/topic/932920-are-these-normal-temps/#findComment-11398876
