which of these will be best for watercooling
http://www.scan.co.uk/products/ek-kit-l120-water-cooling-kit-cpu-120-rad-xt-ek-fan-x-res-plus-pump-ek-tube-zmt-black10mm-fitting-ek
or
http://www.watercoolinguk.co.uk/p/Alphacool-NexXxoS-Cool-Answer-120-LTST-Full-Kit_30210.html
my case isnt a full watercooler but i can have 1 120mm rad atm but in future i plan to do a complete watercooling upgrade
https://linustechtips.com/topic/9328-watercooling-kits/
To be honest with you - neither are very good - especially if you look to expand in the future. A 120mm kit like this will give you no better temps then most AiO units or a good air cooler. Also, neither include very good pumps. They aren't bad per see, just not great. If you expand in the future to say a 360 rad, cpu and gpu blocks, you may also then want to upgrade your pump.
Personally, if all you case can fit is the case is a 120mm rad, if you can, keep running what you got, or get a better air cooler. Save your money for when you have a better case and then get yourself a decent 360mm rad based kit - which typically come with better pumps.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/9328-watercooling-kits/#findComment-102361
