I need help for buying a new android phone
Hello!
I need help buying a new android phone.
The phone needs to have minimally: 2gb of ram
                                                           dual core processor
                                                           some kind of a decent camera that can capture HD photos
My budget is 200$, so if you find an android mobile phone with the minimal specifications mentioned above, reply the links to this post.
Thanks!
Check out the new nokia phones (2.1, 3.1 and 5.1)
They are not out yet but early reviews seem good
samsung galaxy j5 2017? i have it. it might be stretching the budget but it gets the job done! just get some protection for the glass. it is not that durable
Redmi note 5 pro.
It works with world wide LTE except in the USA
Sudo make me a sandwich
