I'm looking for a case with a vertical GPU mount(preferably with the risor included),a tempered glass side panel and that can fit my dark rock pro 3(163mm)
Hope someone can help?
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/932077-searching-for-a-case/
Almost all "built in" vertical gpu bracket suck and you shouldnt use them if you're using an air cooler on your GPU. They put the card too close to the galss and the fans cant breathe. One that doesnt suck is the Lian Li PC-o11 Dynamic. I do not believe the riser is included though, and it's max CPU cooler height is only 155.
https://linustechtips.com/topic/932077-searching-for-a-case/#findComment-11393589
