S8+ Missing - Help?!
Go to solution Solved by Nogghan,
Just now, Chaos Network said:
yea.....thats about where im at with it
sorry mate, time to start looking for a new phone :(
On sunday, 2 days ago, i dropped my Samsung Galaxy S8 Plus in the lake accidentally while kayaking and did not notice it until 5 or 10 minutes later, where it would have dropped is less than 4 feet deep, but it is a pretty large area that it could have dropped. I went back and forth over where i thought it was for hours trying to get my Gear S3 Frontier to automatically connect to it so i had an idea of where it was, so i could dive in and search for it. No luck. Previous to this i had turned off location services to save battery. Any ideas as to what i can do to find my $800 phone that is in an OtterBox case at the bottom of the lake?
"If you gon be bout it, be bout it bout it" ~ Gavin 'itsjusta6' Simon
I play games - Look at my profile for specs
I love memes. I make bad memes, but I like dank memes, who doesn't?
I am good at editing videos and pictures, feel free to message me if you would like some work done.
Thanks!
Kole Overby
Owner At:
Chaos Network
DanTheNali Videography
Employee At:
Neighborhood Mechanic
Heinen's Powersports
https://linustechtips.com/topic/932034-s8-missing-help/
is the Otterbox case water proof? I would think at this point the phone likely shut off from battery drain. I would wager that its a 100% loss at this point and wont be found.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/932034-s8-missing-help/#findComment-11390526
no, its not, but it helps
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
https://linustechtips.com/topic/932034-s8-missing-help/#findComment-11390531
I owuld think then the phone would be dead if not by battery, then form water damage already.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/932034-s8-missing-help/#findComment-11390533
Just now, Nogghan said:
unless you set up a find my phone feature, as the kids say these days " ya played your self"
i did, but turned off location like 20 minutes before we got in the kayaks to save battery
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
https://linustechtips.com/topic/932034-s8-missing-help/#findComment-11390534
.................... yeah man sorry maybe ask your service provider to do a GPS trace on the phone? they might be able to with your permission i dunno but that would probably just tell you its in a lake not very accurately where anyways, the easiest way to find it now would be a dive suit and time
https://linustechtips.com/topic/932034-s8-missing-help/#findComment-11390536
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
https://linustechtips.com/topic/932034-s8-missing-help/#findComment-11390537
1 hour ago, Fruitsnacc said:
Hire DALLMYD
how?
Edited by Chaos Network
changed my question from "what?" to "how?"
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
https://linustechtips.com/topic/932034-s8-missing-help/#findComment-11390949
