Bare with me cringe for pc vets
Iamnotgod
Okay so I saw my router box had a 5 ghz and a 2.4ghz setting was set to the lower ghz and thought if I can change it improve any performance and did a bit of re search. Then procceded to punch into google 192........ And it brought me to a menu typed in code on bottom of router & then followed some google example and disabled 2.4 and enabled 5 ghz (i did read that it might not work for some router or whatever) now the internet gone and 192....... No longer works when typed into Google so i can't get back to the page to enable 2.4 ghz again dick slap me for being a dumb ho
Plug your computer directly into your modem via Ethernet. Also make sure you're not too far away from the router if you're using WiFi as 5GHz doesn't go through walls all that well, and hence, lower range.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
So that's why I can't watch Mr.Beast at night on my S3 :( Forgot that I have 2.4Ghz too. I was using 5G all the time lol
CPU i7-7700k 5.5GHz Delidded GPU MSI 1060 6GB ARMOR OCV1 +335/+1000 RAM 16GB 2x8 Corsair Vengeance WLED 2400/3000 C14 COOLER Corsair H100i v1 BOARD MSI Z270 SLI SSD Samsung 960 Evo 250G, x3 2T Samsung 860 Evo HDD WDB 4T, WDB 1T PSU EVGA 650GQ80+M CASE Cougar PanzerS
CPU i7-10700k GPU MSI RTX 2080 Duke POS RAM 32GB 2x16 Corsair Dominator Platinum RGB 3200/3600 CL14 COOLER CM MasterLiquid ML360R RGB Push/Pull BOARD MSI MEG Z490 Ace SSD 980 Pro 500G, 860 Evo 1T PSU EVGA 1000P2 CASE Phanteks Enthoo Luxe TG Black
CPU Pentium G4600 GPU MSI GTX 1080 Armor OCV1 +100/+400 RAM 8GB 2x4 G.SKILL Aegis 2133/3000 CL16 COOLER Corsair H100i v1 BOARD MSI H110M Pro-VD-Plus SSD 860 Evo 1T HDD WDB 500G, WDB 1T PSU EVGA 430W Bronze CASE Deepcool Tesseract/ VIVO
SERVERS i5-3470, i5-3470, i5-4590 GPUS MSI 750Ti 4GB, BFG GTS 250 1GB, GTX 690 RAMS 3x 16GB 2x8 1866 C8 PSUS 2x EVGA 1000T2 COOLERS Stock, Stock, Custom Loop BOARDS Intel, Intel, EVGA Classified SSD x3 860 250G HDDS I don't care to list CASES Optiplex, Optiplex, 2000s Water Case
560HP/607TQ E85 198MPH2000 Audi S4 2.7Bi-Turbo with K04/RS6 Inlets SRM -  DAZ Tune - 2.8L N/A DOHC Heads  -APB Block - Mahle Pistions - JHM Racing H-beam Rods - TheTuner Manifolds - 3.5in to 3in Exhaust with Magnaflow Dual Box - Dual Titanium Exhaust Tips - SAI CNC Delete - S4 Modified Airbox - 85MM Maf- RS4 Intake Manifold p&p RS4 Y-pipe - RS4 Bi-pipes - RS4 Fuel Rail - A8 TTB - Billet Divertervalves - Silicone Hose Everything - SRMv4 Intercoolers - Clutch Fan Delete/Block off - Power Steering Light Pully - FluidAmper - Billet Cam gears - V8 Cam Bolts - ABS Relocate - VW Diesel Oil Pump
Im in the same room as the router and there no wifi signal and i dont have a ethernet cable
Yep. So 5GHz provides better data rates, but at the cost of shorter range.
My room is outskirts of the house and the router is in the middle.
Why not just factory reset router and set it up fresh? @Iamnotgod
Did you mean to replay the OP?
If you did mean to reply to me, that''s not going to work, I'm around 50 feet away and my house is made of concrete blocks, I live in Florida, the house is rated Category 5+ ;)
It's not a issue for me. 720p is top of what my phone does atm lol.
The router's web page, if you will, should be the IP address of the default gateway, assuming there's a connection to the router. To find this out, open up the command prompt and type in ipconfg /all, look for the adapter that's connected to the router, and then look for "Default gateway" entry.
Yes, sorry.
As for you, if you ever want to upgrade you could look at Power Line Networking, a pair of those and a hub or access point in the room you want would work well (so long as your electrical lines are not total garbage).
