Hello, so for the past month or so I have been troubleshooting my computer due to no post. the reason this happened was because I was cleaning my computer and I put the 4 pin power connector from the 20+4 into my cpu power ?, and lets just say a ton of smoke came out what looked to be the motherboard. Before ordering another motherboard, all the fans would stay spinning just no display or lighting of the caps lock on the keyboard (no boot) but after ordering the motherboard my psu makes a clicking sound, I’m experienced so please don’t say things like, “are all your connections secure” etc. just your opinion on the next thing I should buy next. I might have shorted the cpu or messed up the power output on my psu. Please get back quick. I’m moving soon and my mom isn’t gonna let me take a dead computer till I prove it works
Specs:
Corsair HX 850 psu
Amd a-10 7850k
MSI r9 390
8 gb ddr3
samsung 120 gb ssd
54913864978__AA4405F0-F48A-458A-A7EA-31D0974BC52B.MOV
https://linustechtips.com/topic/931362-urgent-computer-problem/
That computer is dead as can be and you'll have to test each bit by itself to find out what's truly dead but you'll be lucky if you didn't fry the board and CPU together.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/931362-urgent-computer-problem/#findComment-11384222
Wait, is it even possible to put a 20+4 pin in a CPU header... I thought those were key'd differently exactly to prevent this kind of things from happening.
In any case, any or all of the following may be dead:
Motherboard.
CPU.
RAM.
Power Supply.
It's possible that the GPU was also fried, but I doubt it, if possible test things like RAM, GPU and drives in another PC.
https://linustechtips.com/topic/931362-urgent-computer-problem/#findComment-11384235
7 minutes ago, Nogghan said:
let us all press F for that now dead A10 it died doing what it loved, eating power
F
i7-4790k | MSI Z97 GAMING-5 | Corsair Vengeance 16 GB | Samsung EVO-850 250GB SSD & WD blue 1 TB HDD | EVGA 1070 SC | Red NZXT H440 | Cooler Master G650W
https://linustechtips.com/topic/931362-urgent-computer-problem/#findComment-11384298
Yep it's dead. Surely you would've noticed that was the wrong harness since it'll have a giant 20pin connector dangling with the extra 4 pin connector... Plus the pins shouldn't even fit. The layout of the pin shrouds are completely different.
Related imageImage result for 24 pin power
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/931362-urgent-computer-problem/#findComment-11384314
Specs:
Corsair HX 850 psu
Amd a-10 7850k
MSI r9 390
8 gb ddr3
samsung 120 gb ssd
You should try replacing the power supply first as if there's something wrong with the current one as a result of this debacle, it could end up frying new parts you try with it so better be safe than sorry and start with that.
https://linustechtips.com/topic/931362-urgent-computer-problem/#findComment-11387501
