ok so basicaly im purchasing pc parts to build my first pc, but i wanted RGB. im getting the cooler master h500p and the asus z370 TUF. the mobo only has 1 RGB header but im planning on getting 5 more RGB fans plus the two 200mm RGB fans that come with the case. everything RGB im getting has asus aura sync. how do i plug in all 7 RGB fans if i only have 1 RGB header on the mobo, i thought about getting the cooler master fan controler but it only has 4 slots. so my question is, how do i plug in all 7 RGB fans without losing the aura sync feature
https://linustechtips.com/topic/931183-rgb-headers/
Welcome to the forums!
For RGB syncing you can wire up more than one device to an RGB header using splitters. As you add more devices the more amperage it will draw so you must calaculate the total your devices will use and ensure it stays below the max amperage the header can supply. There are power RGB splitters if you need to distribute it to many RGB devices or if it goes past the rating of the header.
-Moved to Modding Section-
https://linustechtips.com/topic/931183-rgb-headers/#findComment-11382801
but the thing is im from australia where half the stuff doesnt ship here. also my question was, if i use a splitter or controler, willi lose the aura sync feature
https://linustechtips.com/topic/931183-rgb-headers/#findComment-11382811
The sync feature is all software dependent from the header of the motherboard splitters will only allow for more devices to connect to it. That silverstone RGB hub is ideal for something like this since it can provide auxiliary power.
https://linustechtips.com/topic/931183-rgb-headers/#findComment-11382824
alright awesome that what ive been trying to figure out for about a week. thanks
https://linustechtips.com/topic/931183-rgb-headers/#findComment-11382831
do you mean the silverstone fan hub or RGB hub
https://linustechtips.com/topic/931183-rgb-headers/#findComment-11382844
1 minute ago, Hitesh Reddy said:
also is this compatible for any RGB fan or just the silverstone RGB products
The connector Silverstone uses is the JST XH type which is different form the basic 4 pin used on RGB products. Depending on what fans your getting you may need something like theses to connect to the hub:
https://www.silverstonetek.com/product.php?pid=774&area=en
https://linustechtips.com/topic/931183-rgb-headers/#findComment-11383200
im getting the cooler master, master fans pro. 4 of my fans use 3 pin connectors and the other 3 use 4 pin connectors am i going to need the cable
https://linustechtips.com/topic/931183-rgb-headers/#findComment-11383221
Your fans if they are RGB they will have a 4 pin and a fan connection is completely different form the RGB system for fan control.
Also if you can get it Akasa also makes an RGB power hub for devices that use the standard 4 pin connector, while being able to sync.
http://www.akasa.com.tw/update.php?tpl=product/product.detail.tpl&no=181&type=Gaming&type_sub=RGB LED Lighting&model=AK-RLD-02#
https://linustechtips.com/topic/931183-rgb-headers/#findComment-11383232
so which one would you reccomend, and which one is cheaper because the akasa doesnt have a listed price
https://linustechtips.com/topic/931183-rgb-headers/#findComment-11383238
never mind i found one on amazon for 90 aud. i think the silverstone one is better. it has more fan inputs for cheaper. also ive never heard of akasa so im gonna go with the branded one
https://linustechtips.com/topic/931183-rgb-headers/#findComment-11383240
Just remember those adapter cables due to the different connection.
https://linustechtips.com/topic/931183-rgb-headers/#findComment-11384196
