Block Material
Solved by W-L,
9 hours ago, mikelthebeast said:-SNIP-
All nickel based blocks are made with a base material of copper since it's a good conductor of heat. As mentioned the reason for the plating is for aesthetics since copper will oxidize readily. For nickel block you do have to take some precautions such as not using silver kill coils in your loop and a compatible fluid/biocide since using the wrong one can cause flaking or damage the plating.
