when i play overwatch or fortnite, my external 144hz monitor i use via hdmi (when im not using the monitor i get crashes but instead of the screen dying the game crashes) and when using the monitor, it sometimes crashes but usually flickers a little and then dies out, with game and sounds still running. Fix please cant even run any games. When i get into a fight it uses more power and the gpu sorta just dies and thats when it starts happening.
https://linustechtips.com/topic/930410-laptop-gpu-not-getting-enough-power/
can it be a bad power outlet or some retardation?
Did you update to the latest drivers, and what is your gpu?
System
  • CPU
    i7-7700k at 4.6ghz
  • Motherboard
    Asus ROG Z270-E
  • RAM
    Gskill 16gb 2400 RGB
  • GPU
    MSI GTX 1080 Duke
  • Case
    Corsair 750D
  • Storage
    Samsung 850 evo 500gb
     WD black 4tb
     WD blue 1tb
     Kingston ssdnow v300 128gb
  • PSU
    Corsair HX750
  • Display(s)
    2x Asus - VG248QE 24" 144Hz 1080p
  • Cooling
    Corsair H110i
  • Operating System
    Windows 10 Pro
does it happen when your not plugged in?
System
  • CPU
    i7-7700k at 4.6ghz
  • Motherboard
    Asus ROG Z270-E
  • RAM
  • GPU
    MSI GTX 1080 Duke
  • Case
    Corsair 750D
  • Storage
     WD black 4tb
     WD blue 1tb
  • PSU
    Corsair HX750
  • Display(s)
  • Cooling
    Corsair H110i
  • Operating System
    Windows 10 Pro
Just now, overturnedv1 said:
No, ive used it for FPS games since september, started having problems at the end of march.
and its only happens when the power brick is plugged into the laptop?
System
  • CPU
    i7-7700k at 4.6ghz
  • Motherboard
    Asus ROG Z270-E
  • RAM
  • GPU
    MSI GTX 1080 Duke
  • Case
    Corsair 750D
  • Storage
     WD black 4tb
     WD blue 1tb
  • PSU
    Corsair HX750
  • Display(s)
  • Cooling
    Corsair H110i
  • Operating System
    Windows 10 Pro
but does it crash?
if it isnt plugged in the games are locked at 30 fps so i cant check
System
  • CPU
    i7-7700k at 4.6ghz
  • Motherboard
    Asus ROG Z270-E
  • RAM
  • GPU
    MSI GTX 1080 Duke
  • Case
    Corsair 750D
  • Storage
     WD black 4tb
     WD blue 1tb
  • PSU
    Corsair HX750
  • Display(s)
  • Cooling
    Corsair H110i
  • Operating System
    Windows 10 Pro
gonna test rn
because if it does not your power brick might be at fault. If it does crash then it might be internal. Your warranty should cover either situation.
System
  • CPU
    i7-7700k at 4.6ghz
  • Motherboard
    Asus ROG Z270-E
  • RAM
  • GPU
    MSI GTX 1080 Duke
  • Case
    Corsair 750D
  • Storage
     WD black 4tb
     WD blue 1tb
  • PSU
    Corsair HX750
  • Display(s)
  • Cooling
    Corsair H110i
  • Operating System
    Windows 10 Pro
yes it crashes on battery (unplugged
then its a motherboard issue, i suggest call your manufactures customer service and RMA for a new laptop or if they can fix the issue.
System
  • CPU
    i7-7700k at 4.6ghz
  • Motherboard
    Asus ROG Z270-E
  • RAM
  • GPU
    MSI GTX 1080 Duke
  • Case
    Corsair 750D
  • Storage
     WD black 4tb
     WD blue 1tb
  • PSU
    Corsair HX750
  • Display(s)
  • Cooling
    Corsair H110i
  • Operating System
    Windows 10 Pro
