Hello! I have Phanteks P400S Eclipse PC case. I have a problem about installing fans in this case.
How much fans should i buy, 120 or 140? I can't install 3x 120mm fans in rear side. C for example.
can 140mm fan fits to A side? In picture
B : 2x 140mm
C : 2x 140mm?
Sorry for bad english.
https://linustechtips.com/topic/930378-p400s-fan-question/
What are your specs and what are you looking for in your fans?
https://linustechtips.com/topic/930378-p400s-fan-question/#findComment-11376371
