Well if your budget is $1000 USD including peripherals then you may be hard pressed. But here's one without the peripherals https://pcpartpicker.com/list/Zgs89J
Here is another that is microATX but would still work fine for gaming with good frames, gives you a little bit more wiggle room for a monitor and kb https://pcpartpicker.com/list/c9nxsZ
https://linustechtips.com/topic/930320-help/#findComment-11374062
--Assuming no peripherals and US budget--
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  ($239.00 @ SuperBiiz)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.99 @ Amazon)
Motherboard: Asus - TUF Z370 Pro Gaming ATX LGA1151 Motherboard  ($129.99 @ Amazon)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($159.89 @ OutletPC)
Storage: Crucial - BX300 240GB 2.5" Solid State Drive  ($71.90 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: Asus - GeForce GTX 1060 6GB 6GB Dual Video Card  ($289.98 @ Newegg)
Case: Cougar - MX330 ATX Mid Tower Case  ($24.99 @ SuperBiiz)
Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply  ($49.99 @ Amazon)
Total: $1060.52
Generated by PCPartPicker 2018-05-24 11:17 EDT-0400
CPU: AMD - Ryzen 5 2600X 3.6GHz 6-Core Processor  ($209.99 @ Amazon)
CPU Cooler: be quiet! - PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  ($35.39 @ OutletPC)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  ($137.45 @ Amazon)
Total: $1039.37
Generated by PCPartPicker 2018-05-24 11:18 EDT-0400
---Assuming peripherals are needed---
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($189.99 @ Amazon)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-2800 Memory  ($85.98 @ Newegg)
Monitor: Acer - G246HLAbd 24.0" 1920x1080 60Hz Monitor  ($115.84 @ Amazon)
Keyboard: Redragon - S101 Wired Gaming Keyboard w/Optical Mouse  ($31.99 @ Amazon)
Total: $1057.90
Generated by PCPartPicker 2018-05-24 11:20 EDT-0400
I kept the Z370 chipset just to give you an easier upgrade path if you overclock in the future. You can just drop in a K chip and be good to go.
CPU: Intel - Core i5-8500 3GHz 6-Core Processor  ($189.89 @ SuperBiiz)
Total: $1050.34
Generated by PCPartPicker 2018-05-24 11:23 EDT-0400
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/930320-help/#findComment-11374078
I do have a 144hz monitor, keyboard and a mouse. and yes i live in US. Thank you for this, i will most likely build this
Total: $1060.52
https://linustechtips.com/topic/930320-help/#findComment-11374240
https://linustechtips.com/topic/930320-help/#findComment-11374308
If you have a microcenter nearby and you're looking for some dank RGB bling. You can get this today, but the deals are limited time, so buy soon.
CPU: R7 1700 $167.93 with combo after mail in rebate and taxes applied.
http://www.microcenter.com/product/485472/Ryzen_7_1700_Summit_Ridge_30_GHz_8_Core_AM4_Boxed_Processor_with_Wraith_Spire_Cooler
Cooler: Master Liquid Lite 120 RGB $0 FREE WITH CASE
https://www.newegg.com/Product/Product.aspx?Item=N82E16811119327&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Cases+(Computer+Cases+-+ATX+Form)-_-N82E16811119327&gclid=EAIaIQobChMIua6u9N6e2wIVjMDACh1IOQd5EAQYASABEgJ1RvD_BwE&gclsrc=aw.ds
Motherboard: Asus STRIX B-350-F $85.39 with combo after mail in rebate and taxes applied
http://www.microcenter.com/product/480185/ROG_STRIX_B350-F_Gaming_AM4_ATX_AMD_Motherboard
Memory: 16 GB G.Skill Trident Z RGB @ 3200mhz $179.99. This RAM isn't on the QVL, but should run ok at least stock 2133 MHz. You can try and manually tune these to 2400MHz or higher.
https://www.newegg.com/Product/Product.aspx?Item=N82E16820232498&cm_re=trident_z_rgb-_-20-232-498-_-Product
Storage: WD Blue M.2 500GB SATAIII $109.99 https://www.newegg.com/Product/Product.aspx?Item=N82E16820250091&cm_re=wd_blue_500gb-_-20-250-091-_-Product
Video Card: ASUS STRIX GTX 1060 6GB $340.46 after mail in rebate and $0.47 postage https://www.newegg.com/Product/Product.aspx?Item=N82E16814126113
Alternatively ASUS Strix 8GB RX580's are avaliable for the same price.
Case: H500p (Non Mesh) $90.45 after mail in rebate and shipping (includes postage) https://www.newegg.com/Product/Product.aspx?Item=N82E16811119327&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Cases+(Computer+Cases+-+ATX+Form)-_-N82E16811119327&gclid=EAIaIQobChMIua6u9N6e2wIVjMDACh1IOQd5EAQYASABEgJ1RvD_BwE&gclsrc=aw.ds
Power Supply: Corsair CX550M $35.46 after MiR (includes postage) https://www.newegg.com/Product/Product.aspx?Item=N82E16817139147&cm_re=cx550m-_-17-139-147-_-Product
Total $1009.68 after taxes, Rebates, and postage paid for rebates.
For a RGB-ified dank-BOX, this isnt bad. For a another $15 you can get a mesh front panel and for another $23 you can get a PCIe riser to use the case's vertical mount if thats you kind of thing. (riser will hurt GPU thermals)
Just a lot of mail in rebates...
Share any interests with me? Feel free to message me just to chit chat about whatever.
(Music) Depeche Mode, The Cure, Pink Floyd, Nick Cave and the Bad Seeds, Cocteau Twins, MGMT, Boy Harsher, The Smiths, Drab Majesty, Chelsea Wolfe, Carly Rae Jepsen, The Smashing Pumpkins, Virgin Prunes, Sky Ferreira, London After Midnight, Jonathan Coulton, Alvvays, Clan of Xymox, Bauhaus, Siouxsie and the Banshees, Anna Von Hausswolff, Joy Division, Sisters of Mercy, She Wants Revenge, The Frozen Autumn, My Bloody Valentine, Type O Negative, The Birthday Party, Leonard Cohen, Switchblade Symphony, Metallica, Creedance Clearwater Revival, Eagles, Elton John, Billy Joel.
(Games) PUBG, Metro Series, Command and Conquer games, Warhammer 40,000 games, Company of Heroes (2), RDR2, CoD4
(Other) Going to the goth club, Firearms, Building PCs (Especially budget PC builds), Playing instruments (Guitar, Piano APP for PC, Otamatone, Trombone) Camping, Board Games
https://linustechtips.com/topic/930320-help/#findComment-11374359
6 minutes ago, Tompsu said:
i want to start playing games on PC. my budget is around 1000$ (including windows Home and mouse,keyboard) i want to play games like Battlefield 1 with decent frames, can somebody help me pick parts? thanks in advance
just use windows unregistered for a little bit and put the extra $100 toward a better system for now
https://linustechtips.com/topic/930320-help/#findComment-11378705
-Moved to New Builds and Planning-
2 minutes ago, RollTime said:
What resolution? 144Hz is HARD with a $1000 budget.
If you can grab a 1070, 144Hz should be a piece of cake.
https://linustechtips.com/topic/930320-help/#findComment-11378711
PCPartPicker part list: https://pcpartpicker.com/list/Nc4ZJ8
Price breakdown by merchant: https://pcpartpicker.com/list/Nc4ZJ8/by_merchant/
Motherboard: MSI - B350M GAMING PRO Micro ATX AM4 Motherboard  ($64.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory  ($94.99 @ Newegg Business)
Storage: Kingston - A400 120GB 2.5" Solid State Drive  ($39.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($42.99 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1070 Ti 8GB Video Card  ($469.99 @ Newegg)
Power Supply: EVGA - SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($75.98 @ Newegg Business)
Total: $1003.91
Generated by PCPartPicker 2018-05-25 14:32 EDT-0400
https://linustechtips.com/topic/930320-help/#findComment-11378712
Just now, RollTime said:
That's half the budget gone right there.
Used market 980Ti?
https://linustechtips.com/topic/930320-help/#findComment-11378722
Total: $1003.91
Stay away from MSI's B350 boards, they are known to have bad VRMs. I would get an Asrock Pro4 instead.
https://linustechtips.com/topic/930320-help/#findComment-11378729
I have to admit I'm not too knowledgeable about AMD stuff. If only he'd asked for an i5.
xD
I only heard about this because I got a Ryzen system and I'm fairly active in the build plan section.
https://linustechtips.com/topic/930320-help/#findComment-11378746
