I am planning to build to build new PC for the first time, till now I have invested in laptop as I am generally on the go. My Dell has given up on me and I have Mac-book for general use but need PC for simulation, modelling and lite MOBA and FPS gaming. Confused between 2600x and i5-8600/K, along with which motherboard to pick. I guess AMD bought competition with chaos. Can't decide need help!!! Ballpark for build would be around $800.
And yes I have watched all the tutorial and reviews but in my experience review sometimes vary than the actual real-time use. So input would be extremely valuable.
Thanks.
https://linustechtips.com/topic/930009-pc-build-first-timer/
Where are you from? Do you have any parts already? Do you have a monitor/other peripherals?
$800 budget is limited for your use case, as far as I know, simulations and modeling are resource intensive.
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
https://linustechtips.com/topic/930009-pc-build-first-timer/#findComment-11370981
as you might know, amd is more for the multicore perposes. I will not make the choise for you, but keep what I say in mind.
AMD: 3000+ mhz ram recommended with a B350 motherboard (you won't miss too much), know you'll need a cooler with it, they dont give you one with that chip
Intel: 2666+ mhz ram recommended with a z370, even if you don't want to go to the k series for now, if you want to make a upgrade to a later 8/9 series chip you'll be happy with it. also K series don't have a cooler with it, keep that in mind
https://linustechtips.com/topic/930009-pc-build-first-timer/#findComment-11370991
I am in IOWA, US. I have monitor and other peripherals. I am not doing rocket science simulations and modeling just normal data flow analysis of air crafts. I have office PC so that works but in my spare time I wanna have a machine that can do stuff so CPU I was down to 8600k and 2600x but confused after that.
https://linustechtips.com/topic/930009-pc-build-first-timer/#findComment-11370992
i think maybe 2600 as mobo is cheaper as well as not paying extra to overclock
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/930009-pc-build-first-timer/#findComment-11371019
