hwinfo is a good one to measure and aida64 is both good at measuring and stressing the system.
You can also use cinebench to measure a potential performance increase.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/929500-need-help/#findComment-11365904
11 minutes ago, Rahul Grewal said:
Me and my friends have created a new design for heatsink as our college final year project, and were looking for softwares that can help in testing the thermals, can anyone suggest some (except RealTemp ofcourse)
You developed a heatsink? Yo if it turns out to be super good, imma buy one ?
My main rig  Shardsedge
 ☟ INFO & SPECS
  • Information:
This build is made for video editing, Gaming and livestreaming.
probably 65% of this build has been bought used.
  • Specifications:
CPU  AMD Ryzen 7 1700
GPU  Sapphire RX 580 PULSE 4GB
SSD ✦ Toshiba TR200 240GB
HDD ✦ WD Black 160GB 2.5" + WD BLUE 1TB
PSU ✦ Corsair RM750X
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 3000Mhz
CASE ✦ Corsair Crystal 460X
MOBO MSI X370 SLI Plus
My old pc build  Smoke
 ☟ INFO & SPECS
  • Information:
This build was made for gaming especially, it was my second build.
i had some struggles livestreaming on it because the CPU just wasn't good enough for that.
(I do not have this build anymore)
  • Specifications:
CPU ✦ Intel i5 6500
GPU  Sapphire NITRO+ Radeon RX 470 4G D5
SSD ✦ Kingston SSDNow v300 120GB
HDD ✦ WD Blue 1TB
PSU ✦ Corsair CX450M
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 2400Mhz
CASE ✦ Sharkoon S25-V
MOBO ✦ MSI H110M ECO
https://linustechtips.com/topic/929500-need-help/#findComment-11365905
Trust me, its just a stupid final year project and is not gonna work, we are comparing it with the intel stock cooler as its would be around the same price, eventually we gonna right in conclusion that intel stock cooler is the best in that price range (if that even is correct) :P
https://linustechtips.com/topic/929500-need-help/#findComment-11365926
I'd argue that taking a dump on your motherboard would be a better way to cool your CPU than the stock cooler, but still :P
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/929500-need-help/#findComment-11365985
