14 minutes ago, stgbruz said:
Hey I'm new to building PC's and barley know about PC parts I was wondering if these parts are good.
https://pcpartpicker.com/list/2Ckv3b
For that sort of budget, go used. Plenty of off lease Business machines in the Core i3/i5 range are around 200 bucks at that price range.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/929481-pc-350-budget-help/#findComment-11365775
Found this on pcpartpicker already done https://pcpartpicker.com/guide/DhLrxr/budget-homeoffice-build   note I would go for a cheaper motherboard probably ATX for expandability unless you like a smaller tower. Also with cheaper motherboard and ATX form factor a cheap atx case though this is only the r3 2200g
https://linustechtips.com/topic/929481-pc-350-budget-help/#findComment-11365788
Try and find an old OptiPlex on eBay and buy a separate graphics card like a GTX 1050 or a GTX 750ti. They are still very capable cards these days, and can be found on the cheap. Your AMD system will be very slow and not worth $350. When buying an OptiPlex, make sure it has at least 4GB of ram, and a 4th gen i3 or i5. Some other people have also implied a Ryzen based system using integrated graphics. The integrated graphics on the Ryzen 3 2200g are very powerful and will play your games at a range of settings around medium at 1080p. Nothing higher though. When you have saved up some more, you can purchase a dedicated graphics card to make your games run smoother and look better.
hi.
https://linustechtips.com/topic/929481-pc-350-budget-help/#findComment-11365817
