I can't choose help men pls!
ManosMax13
I want to buy a new display. The first one that I have in mind is this https://www.amazon.com/Acer-Predator-XB271HU-bmiprz-2560x1440/dp/B06ZXZ3QBD/ref=sr_1_4?s=electronics&ie=UTF8&qid=1526939402&sr=1-4&keywords=acer+gaming+monitor+ips
However I can get this for around 100 dollars cheaper or the same price it depends https://www.amazon.com/Acer-Predator-XB271HU-bmiprz-2560x1440/dp/B06ZXZ3QBD/ref=sr_1_4?s=electronics&ie=UTF8&qid=1526939402&sr=1-4&keywords=acer+gaming+monitor+ips
And then I saw this.Personally I don't believe that g sync is worth that much even though I have a 1080.https://www.amazon.com/LG-34UC89G-B-34-Inch-21-UltraWide/dp/B0728JH3RQ/ref=sr_1_4?ie=UTF8&qid=1526939597&sr=8-4&keywords=lg+ultrawide+gaming+monitor
Which should I buy,I want to buy the ultrawide but will 1080p in 34inc look soooo bad???
I'd personally get the Acer (by the way, the first two links are to the same monitor) since 1080p might look bad on a 34" ultrawide like you said. Another option would be a 144Hz, G-Sync, 1080p monitor, since I feel like your 1080 won't be getting 144FPS at 1440p in more than e-sports games (but it might, and I might be talking out of my ass).
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
