Hello Everyone. I am a hardware guy to the core so software is my biggest weak point. My PC won't boot to windows 10. When I turn the PC on it will go to a black screen with a flashing cursor. I tried changing the boot order, didn't work. I turned off all overclocks on my cpu and memory. Any other ideas on what I should do guys?
https://linustechtips.com/topic/927980-need-help/
As dumb as this sounds, Unplug the boot drive and replug it again xD. Seriously try that :P. Unplug the boot drive and boot it up. Then power it down and then replug the boot drive again. See if that works :P
Primary Laptop (Gearsy MK4): Ryzen 9 5900HX, Radeon RX 6800M, Radeon Vega 8 Mobile, 24 GB DDR4 2400 Mhz, 512 GB SSD+1TB SSD, 15.6 in 300 Hz IPS display
2021 Asus ROG Strix G15 Advantage Edition
Secondary Laptop (Uni MK2): Ryzen 7 5800HS, Nvidia GTX 1650, Radeon Vega 8 Mobile, 16 GB DDR4 3200 Mhz, 512 GB SSD
2021 Asus ROG Zephyrus G14
Meme Machine (Uni MK1): Shintel Core i5 7200U, Nvidia GT 940MX, 24 GB DDR4 2133 Mhz, 256 GB SSD+500GB HDD, 15.6 in TN Display
2016 Acer Aspire E5 575
Retired Laptop (Gearsy MK2): Ryzen 5 2500U, Radeon Vega 8 Mobile, 12 GB 2400 Mhz DDR4, 256 GB NVME SSD, 15.6" 1080p IPS Touchscreen
2017 HP Envy X360 15z (Ryzen)
PC (Gearsy): A6 3650, HD 6530D , 8 GB 1600 Mhz Kingston DDR3, Some Random Mobo Lol, EVGA 450W BT PSU, Stock Cooler, 128 GB Kingston SSD, 1 TB WD Blue 7200 RPM
HP P7 1234 (Yes It's Actually Called That)  RIP
Also im happy to answer any Ryzen Mobile questions if anyone is interested!
https://linustechtips.com/topic/927980-need-help/#findComment-11352838
It still should. It will be significantly more annoying to do so but it should do it
https://linustechtips.com/topic/927980-need-help/#findComment-11352848
Does your motherboard has POST codes (A display that shows numbers and letters?), If so, what code does it show, and refer to the motherboard manual for it's meaning.
Can you access the BIOS/UEFI? Does your motherboard have a BIOS/UEFI button, and can you press it (try it with the computer being off, and if that does nothing, do it while it is on)?
Also, the problem can be as simple as the CPU power plug is miss connected or not plugged in properly, same for your GPU and Motherboard connector. Make sure everything is fully inserted, and not missing a power connector.
https://linustechtips.com/topic/927980-need-help/#findComment-11352852
Yes I can get to the bios and the readout is switching between 37 and 38
https://linustechtips.com/topic/927980-need-help/#findComment-11352876
