10" width by 8" length by 3.5" that is the nes size, great sff size, anyway can a mITX, a gpu a sfx psu (in the back) & a slim ODD fit... I think a 3.5 cutout for a i/o panel would also be cool, but not needed, but it would be awesome to upgrade the i/o panel to match mb front i/o...
GIGA AORUSBYTE B550I PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) ,AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked 4.7 GHz, TEAMGROUP T-Force Vulcan Z DDR4 32GB (2 x 16GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
https://linustechtips.com/topic/927944-is-it-possible-case-idea/
Smallest case I know of is http://www.louqe.com/
12.75" x 5.75" x 7.25"
It is stupid, but no ODD bays in cases seem strange...
