939 cooler on 1150 ?
The321
Would it be possible to put a 939 cooler on an lga 1150 motherboard if soo how ?
Stock cooler? With zipties maybe. But why? Or rather which CPU it would be cooling? You have better lock getting aftermarket cooler.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
@LoGiCalDrm it is a 120w cooler and should only be cooling a 50w cpu. Also that cooler is just catching dust would like to reuse it
So its not stock? What cooler is it? If it is anything newer (like 212 and others from CM), you can probably find brackets from eBay etc. Otherwsie its still zipties.
