Consider getting better case. P-series from Phanteks aren't the best for airflow and many air coolers suffer because of that. What RAM you are going to use?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
10 minutes ago, Baltazar03 said:
hyperx fury ddr4
Depending on your budget... Cryorig H5, be Quiet! Dark Rock 3, Scythe Fuma, Scythe Mugen 5 etc. Or you can get 240-280mm AIO if OCing to max is what you are looking for. Becuase of RAM and case combined, you can't have bigger aircoolers like Dark Rock Pro 4, D15 or Cryorig R1.
What cpu are you cooling? Are you oc'ing?
Where are you shopping/located? Budget?
