Build discussion & help. (Coffe lake time)
Solved by stealth80,
1 minute ago, M300843499 said:
I did not see that ACER was G-Sync! definitely will swap for the ACER for the cost saved, thanks!
8700K fit's nicely into that budget now hmm.
if you can find another £200 you can get a 1080ti, which is a big upgrade from the 1080, also, to throw another spanner - new cards from Nvidia in July/August
