obs Problems of streaming PUBG
29 minutes ago, MaxBeast4Z said:Here are my results it's in a stream clip.
https://clips.twitch.tv/JazzyAverageHabaneroGOWSkull
Everything looks fine I just don't understand why it does that it's really annoying on stream you don't see it but what I'm looking at on my monitor it's terrible.
Ok so it seems that your frametimes do in fact spike around the time you said it feels bad. As to what is causing this I am not to sure. Might be worth using DDU to uninstall your drivers than reinstall the latest ones from nvidia, validate your game files for pubg using steam and navigate to
C:\Users<Your_user>\AppData\Local\TslGame\Saved\Config\WindowsNoEditor\GameUserSettings.ini
{/Script/TsiGame.TsiGameUserSettings}
bUseVSync=True (to turn on vsync)
FrameRateLimit=60.000000 (to set fps limit)
and set the frame limit to say 60fps and see what happens. you can also try turning on vsync to see if that helps although it will increase input lag. Not sure of any of these will help but try each one, one at a time and see what happens.
Nice streaming setup BTW, might tune in sometime.
Also the app data folder is hidden so use the run command or turn on hidden folders to find the GameUserSettings.ini
