It wakes me up to which is the biggest issue. yes I know powercfg -lastwake I did that.  it says usb20 hub so I check which one that is. and that is the issue. in the picture is the device. hub20. yes I checked the rest as well. So I don't know how to fix this  like you would easily with programs or a actual usb device.
CPU: i9 19300k////GPU: RTX 4090////RAM: 64gb DDR5 5600mhz ////MOBO: Aorus z790 Elite////MONITORS: 3 LG 38" 3840x1600 WIDESCREEN MONITORS
https://linustechtips.com/topic/925539-computer-keeps-waking-up-help-please/
4 minutes ago, Dissitesuxba11s said:
Right click it --> Properties --> Power Management then uncheck "Allow this device to wake the computer.” I had the same issue but found out it was my network connection waking my PC.
there is no power management.
1 minute ago, AshleyAshes said:
THIS is the font you are using in your Windows!?  I just......I can't...But...You...  *dies*
yes
I would check inside your BIOS (hit F2 a bunch of times on boot) and find a section for "Power Management" or for your USB settings. In there you should be able to turn off USB wake function all together on your system.
P.S. Your font in Windows made me puke... LOL
P.P.S. I love your Username... Please never change it xD
1 minute ago, Dissitesuxba11s said:
Can you provide a screen shot of the Properties page?
open explorer put this as ur location
Control Panel\Hardware and Sound\Power Options
or windows + x  and power options > additional power options (win10)
or windows + r > powercfg.cpl
need more ways to get there? coz ther are :v
that isn't the power management he is talking about?
42 minutes ago, Dissitesuxba11s said:
Are you signed in as Administrator? For convenience here are the instruction I followed to solve my problem.
looked through it. no events for power troubleshoot.  I don't know why there is so many keyboards but all I have plugged in is mouse keyboard and the razor one. but none of them match the number "20"
u can disable some power management stuff there too to help resolve the issue
allow usb device to wake up pc <  can disable ect
the hub is not a usb device. chip set x99 is not a "device". and I still want me keyboard and mouse to wake my pc up
