Hi all. Me and my brother decided to do some fun bench marking a short while ago (15 minutes). We were using an i7 7700k on a Z270F board, using the Corsair H115i.
We used the Passmark benchmark, PerformanceTest 9.0.
Case fan configuration was 2 140mm intakes and 1 140mm exhaust, with the radiators going at full speed ONLY when the CPU hit 60c.
We were using the CPU benchmark.
These were the results.
4.8GHz - 13553
5.0GHz(First time he has dared go to 5.0GHz) - 13895
5.2GHz - 13938
5.3GHz - Crashed at 10% progress. Not sure if it was the CPU or Motherboard.
What is the highest you have hit your 7700k?
Our results were 5.2GHz at 1.24 Vcore reaching a maximum of 65c.
TJ
hi.
https://linustechtips.com/topic/925502-7700k-clock-speed/
4.8GHz - 13553
5.2GHz - 13938
TJ
5.2 at 1.24v? Did you even run a stress test to check stability?
https://linustechtips.com/topic/925502-7700k-clock-speed/#findComment-11328656
7 hours ago, faziten said:
he is overclocking for high scores and lulz not for stability.
OP tried overclocking uncore? it may give slightly better synthetic results.
The overclocking was done by using a tool on the PC. We didn't change any settings in the BIOS.
hi.
https://linustechtips.com/topic/925502-7700k-clock-speed/#findComment-11330992
