Best memory for Ryzen 2700x
Go to solution Solved by Colb,
Trident z RGB for amd  3600 is probably the best . Just make certain if you choose other that it's b die Samsung for the least hassle
Forgive me El Guapo. I know that I, Jefe, do not have your superior intellect and education...
6 minutes ago, Some Random Member said:
Ryzen 2 has much better memory compatibility with the x470 mobos, so it should run at that speed fine.
The G-skill 3600mhz ones should work fine too, but i dont know about the 4133Mhz ones.
Thanks
Can't go wrong with the kits AMD recommends for reviewers, which are the G.Skill Flare X 3200: https://www.newegg.com/Product/Product.aspx?Item=N82E16820232530&cm_re=g.skill_flare_X_3200-_-20-232-530-_-Product
Can get some serious performance gains, especially for gaming, if you tweak the timings:
12 minutes ago, donalgodon said:
Buying online, how can we be sure to get Samsung b?
Its a bit confusing, generally speaking most 3200 CL14 kits are B Die, whereas the CL16 kits are not.
Best to just link it here and we can confirm for you
Is there any 3600 CL14?
Does latency matter more than speed itself? (i.e. CL 14 3200 vs. CL 16+ @ 3600?
What about the Sniper X RAM that was included in the Ryzen+ reviewer kits? Is it b-die?
https://www.amazon.com/G-Skill-F4-3200C16D-16GSX-288-Pin-PC4-25600-Desktop/dp/B07BH1CQVQ/ref=sr_1_1?s=local-services&ie=UTF8&qid=1525963338&sr=8-1&keywords=Sniper+X+memory
