I have a thredripper 1950x on a asrock mother boadard and post code 92 after doing a BIOS update.  Tried reflashing the BIOS with different versions no success. Ordered I a new motherboard Gigabyte Designate EX. Got everything put together and same problem, code 92. Do I have a dead cpu? Any thoughts?
https://linustechtips.com/topic/925338-thredripper-post-code/
http://forum.gigabyte.us/thread/715/faq-led-error-codes
Code 92 is PCI bus issues.. like a graphics card or other PCI device plugged into it.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/925338-thredripper-post-code/#findComment-11327280
Code 92 is for PCI Bus initialization Started.
You sure you have a GPU plugged in or something?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/925338-thredripper-post-code/#findComment-11327284
18 minutes ago, Grant Hansen said:
Done that 2 different gpus and just swapped the power supply. Nothing different.
Do the GPUs you used work in other systems without issue?
Community Standards
"Beast Mode"
https://linustechtips.com/topic/925338-thredripper-post-code/#findComment-11327339
