On 5/8/2018 at 1:12 PM, AngryBadAss said:
If you have any ideas for my build or any help, I would love to hear it...
All u need is cable management
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/924921-personal-build-help/#findComment-11323125
8 hours ago, ErykYT3 said:
I think you should invest in a new case...
It looks pretty good but the case appears to be quite old, I cant tell if the cable management is poor or if you need a bigger case but I'll go with the latter.
It's a Corsair spec 03, just today I started work on mounting that to my desk
https://linustechtips.com/topic/924921-personal-build-help/#findComment-11324682
