Hello, I'm building my first pc and im stuck with choosing my display, I've been looking forward on getting this one:
http://www.microcenter.com/product/502869/XF270H_27_TN_Gaming_LED_Monitor (270)
But just now I saw good discounts for
http://www.microcenter.com/product/506027/Y27g_27_VA_Curved_LED_Monitor (300 on newegg) which has gSync, 4ms latency?
But then for 300 you can also get 1440p with 1ms 144Hz
http://www.microcenter.com/product/503505/KG271U_27_TN_WQHD_LED_Monitor (300)
My price range is ~300$. I have Nvidia 1070Ti. I will be playing variety of games from PUBG and Tarkov to Civ V and Sims (wife :D).
So questions I have:
1. Does gSync really gives anything at 1080p with 1070ti?
2. Does 1070ti is enough for 1440p 144Hz without gSync? I'm okay reducing shadows and texture details in AAA games, but wouldn't want to go to 1080p when using 1440p monitor.
3. Does VA quality is worth losing the speakers and 1440p compared to TN?
4. Is there some alternatives at this price range without going to 60Hz?
5. I think 4ms latency vs 1ms latency shouldn't make a difference?
Thank you all in advance
https://linustechtips.com/topic/924854-help-me-choose-display/
The First one or the last one. both have 1ms which is important.
The first has no sync ability
the last has free sync which nvidia can use
vid on a demo n review from google search. Here
I would personally get the last one with 1ms and freesync @ 1440p but still has 144Hz refresh rate. (meaning it will match the video card upto 144FPS and with freesync match what the 1070 Ti is outputting so you will not get screen tearing
PSU Tier Ranking List
Ryzen 5 1600x|ASROCK                      |16GB DDR4 3400Mhz Corsair Vengence   | (partial build in progress)
FX-8350 AM3+| ASUS M5A990FX V1 | 32GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H100i v1
FX-8120 AM3+| ASUS M5A990FX V2 | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H80i v1
I5-2500K LGA  | ACER MOBO??         | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 860 PRO | Win 10 64 Pro | EVGA 750W G PSU | EVGA 970 SC 4GB | Corsair H80i v1
https://linustechtips.com/topic/924854-help-me-choose-display/#findComment-11322359
I don't think that number is quite as important as you may think. The first two sections in this post explain why:
ummm... no. Where'd you get that from? FreeSync is not compatible with Nvidia GPUs.
https://linustechtips.com/topic/924854-help-me-choose-display/#findComment-11322450
Any idea for a benchmark list on real latencies? I've tried searching but found only few displays listed.
https://linustechtips.com/topic/924854-help-me-choose-display/#findComment-11326328
I typically find it better to use other characteristics and more objective specs to filter monitors first and once I have a few monitors in mind, I can then look up reviews from like trtcentral or pcmonitors.info and the check stuff like color space, backlight bleed and input lag.
https://linustechtips.com/topic/924854-help-me-choose-display/#findComment-11326548
