https://www.pccasegear.com/wish_lists/816645
This build is MOSTLY focused on Gaming performance.
This build is also trying to maintain as close to $1500 (Australian Dollars) as possible.
If you can think of anyway to improve performance without spending more money please feel free to tell me.
I realise the ram will need upgrading in the future along with HDD and a case, but your opinions are very much welcomed!
Please go easy on me.
https://linustechtips.com/topic/923976-updated-build-plan-input-welcomed/
If you are mostly playing games you may drop to i5-8600k, the 1070ti to a 1070 or check some other places to buy one(also look for 1080s, in my country 1080 is similarly priced to a 1070) and also add at least 8 gigs of ram. You may also use a normal cooler not an AIO.
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
You are not going to have a good experience with 4GB Ram. I would drop down to a GTX 1070 and then up the Ram to at least 8GB. You really should be aiming for 16GB though.
I would go with the Ryzen 7 over the 8700 but that is my opinion and I have used both in gaming enviornments
dafuq is that GPU? no... is the US market still just super screwed or something because 1070TIs are under $600 by quite a bit here, cheapest ones are like $550...
Builds:
Just now, lee32uk said:
Australia...
oh xD just saw a .com and assumes US :P my bad
Builds:
