I realize this has been talked about all over the internet, but I like doing my own research and talking with others SO, here's my question. I have an EVGA 980 Ti FTW that under NORMAL room conditions runs about 63 *C. However my office room got to around 90 *F plus, 32 *C, and my GPU got up to 73 *C. I have some Thermaltake TG-7 paste and I was wondering to myself, should I replace the stock thermal compound with the TG-7 paste in hopes of not only having a newer paste but also possibly lower temps? Also, should I do the same for my CPU which was running about 60 *C yesterday? I live in a rather stupidly humid area and I was wondering if my PC parts could benefit with a Paste change?
AMD Ryzen 9 5950x 3.4Ghz | Asus Prime X570-Pro | Corsair Vengeances RGB PRO 64GB 3200Mhz | EVGA Nvidia Geforce 3060 XC | EVGA G3 SuperNova 750 Watt PSU
https://linustechtips.com/topic/923570-gpu-thermal-paste-replacement/
For how long have you had that card? Also, I don't think 60°C is that bad, although it might be higher if yesterday wasn't too hot considering "your usual conditions"...(I hope you get what I mean, I expressed in a - kind of - unnecessarily complicated way, I think :P )
Make sure to tag and/or quote people so they get notified... :P:D
My gear:
                                                         Ryzen 7 2700X / Gigabyte GA-X370M-Gaming 3 / R9 380 Nitro 4GB/ 16GB DDR4 2133 / 225GB OCZ Trion 100 / 3TB of hard drive storage
        AOC C24G1 / BenQ GW2270H(rarely overclocked to 87Hz :P )
        Razer Blackwidow / Redragon Kumara / Logitech G Pro Wiress / Sennheiser HD 559
        Microsoft LifeCam Studio / Tonor BM700 microphone
Panasonic Lumix DC-FZ82 / Canon EOS 80D
#PCMasterrace
63 C is pretty damn good under normal conditions, and even 73C is pretty damn good.
i wouldn't worry about it at all, not one bit.
same thing about the CPU.
Quote or Tag people so they know that you've replied.
i am also curious about this, i am getting an even older radeon hd 7770 so what paste would be reccomended?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
I'd first test it, but frankly, the HD7770 isn't that new of a card, so it'll somewhat likely to benefit from replacing the thermal paste...
My gear:
#PCMasterrace
Stock thermal compound isn't that bad. As for pastes: https://www.tomshardware.com/reviews/thermal-paste-comparison,5108.html
There's about a 5C spread in pastes, so you could gain a little (I don't know TT's stuff), but unless you're going for maximum overclock you won't notice a performance difference. 60C and 73C  are perfectly fine temperatures for those components to run at under load, and if your ambient temperature rises, so will the temperature of your components. The hotter your surroundings, the more difficult it is to dissipate heat into it. Changing pastes won't change physics.
You may see benefit if the paste has started to dry up over the years, so there's definitely no harm in repasting. Just don't expect massive differences.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
For probably about 2 or more years.
Well I got smart about my fan set up. I have a 3 in 3 out config and also got Corsair's 120ML 2,000RPM fan, put it in the bottom of the case I have and synced it to the GPU temp using Speed fan so as the GPU temp rises the ML120 speeds up sucking more cold air from the bottom floor area. I just wish the Corsair Graphite T760 case had a dust filter at the bottom where the ML fan is but I am unsure what to use to act in that respect of a dust filter.
Yeah, those are way better than founder's edition thermals. If it isn't broke, don't fix it. Now if you go water cooling route... you can knock it down to like 40-50c at least depending on your overclock. I max out my 1080ti on ek all aluminum block, and it goes max 50c at 2060mhz.
I'd say it's worth a shot then, although - to be honest - I don't really know anything about the paste you want to use. But if your card's dirty, I'd first try cleaning it and see if there's an improvement...
My gear:
#PCMasterrace
You can pick up a dust filter on Amazon. They have pre-cut 120mm filters that can screw on under the fan. As stated here already, your temps are well within reason though. I have an MSI GTX 1060 Gaming X and up until 2-3 days ago never got over 69c. Summer has finally decided to hit and now it's sitting around 73c when gaming and even hit 80c for a second yesterday. Replacing thermal paste is never really a bad idea, but I would bet money that you won't notice a temp difference of more then 1-2c
 Current System: MoonLightRyzen
CPU: Ryzen 7 1700x @ 3.9ghz  Board: Asus ROG C6H  Ram: G.Skill TridentZ 32gb 3000mhz  Case: Lian Li PC-O11 Dynamic
GPU: Asus ROG Strix GTX 1070 OC in SLI M.2: Samsung 960 Evo 250gb SSD: Samsung 850 Pro 512gb x2 HDD: Seagate Barracuda 3TB and 2TB
PSU: Corsair RM850x White  Cooler: XSPC/Phanteks Custom Loop
Backup System: RedDragonV3.0
FX-8350 @ 4.7ghz, Asus TUF Sabertooth 990fx r3.0, MSI GTX 1060 6gb Gaming X, Crucial Balistix Tracer 32gb, M.2 Samsung 960 Evo 250,
Seagate Firecudda 2tb, Seagate Barracuda 2tb, NZXT S340 Elite White, Kraken X62, Corsair RM750x, Hue+
Well today I just ran a benchmark with Unigine Superposition. The card started at 1.480Mhz then dropped to 1.455 at 77 *C. My overclock is like +25 on the core and 0Mhz on the Mem. Core Voltage is +97mV, Power is set to 120%. Figured I'd let my GPU have whatever power it wanted. My office is 33 *C. Now yes I completely understand room temp affects component temp, with it going into the high 70s, is that alarming enough to change paste?
Just now, AdamTheSlave said:
Not at all. Normal operating temps for boards on air during intense stressful things is around 80c. You are fine.
Ok. Also, is there a particular type of paste one would use should I want to replace the paste at some point? And why the drop off in clock speed? Is the card suddenly thinking "oh no, I'm too hot, I can't keep the 1480Mhz speed!"?
6 minutes ago, AdamTheSlave said:
Clock speed dropoff starts at 45c to keep the temps under control. Another thing you can do is adjust the fan curve to be more aggressive.
Also, once in awhile, especially in the summer, I actually hear a metal rattling sound coming from the GPU heatsink when the fan speed rises, I am assuming this is because of the laws of how metal expands and contracts based on the heat or cold? Is that normal as well?
i honestly don't get peoples complaints about fan noise when gaming. how often do you actually game without any sound?
Some people game at night and don't want to wake up their loved ones with a noisy blower I would guess. Founder's edition blowers are loud. But I dealt with it by putting the computer in the living room xD Later though I went liquid cooling, and it was nice to max out a system and it's still silent. But yeah, to each their own.
Yeah same, I honestly kinda like the sound of computer fans as it makes a nice ambient sound. Heck, I can actually sleep to the sound of my server which is a LOT hotter than my gaming rig and those fan sounds don't bug me much.
1 minute ago, AdamTheSlave said:
check that it's screwed down tight to the case, could be the plate rattling if it's loose from the fan vibration...
Ok next time I work on my system I will, I can also make sure all the mount screws for the heatsink are tight as well.
Some people game at night and don't want to wake up their loved ones with a noisy blower I would guess. Founder's edition blowers are loud. But I dealt with it by putting the computer in the living room xD Later though I went liquid cooling, and it was nice to make out a system and it's still silent. But yeah, to each their own.
i guess... but assuming that isn't the case, you could just wear headphones.
so can anyone recommend a good thermal paste for around 5 USD?
Yeah I mean, when I am streaming, I am more focused on the game, talking to my chat, listening to music and I seriously don't even realize my fans are going that fast. What I do notice is the insane amount of heat I am in when I sit with a machine that's hot and an even hotter room. :P My house doesn't breath well in the summer so that why I was asking about paste and figuring out whether paste replacement was worth it.
preferably less...
Noctua NT-H1 (1.4ml) or ARCTIC MX-4 (4 gram)
There's no place like ~
Problems and solutions:
FreeNAS
Dell Server 11th gen
ESXI
if i think i will try and goo for perhaps the ARCTIC but can you think of a good one for cheaper?
