Adjustible Monitor for $200
BionicMike
Hi, my mom need a montior that is :
- 21 inches +
- less than 200 CAD
- Has Adjustable (so it can go up and down)
- Has eye protection of some sorts (a monitor that isn't too hard on the eyes)
Are there any avaliable?
The Dell P2217H has all the adjustable-ness you will need and it also features a nice IPS screen with eye-care features available (blue light filter + flicker-free). It's at the edge of your budget but I think it is still a very good option for you:
https://ca.pcpartpicker.com/product/h34NnQ/dell-p2217h-215-60hz-monitor-p2217h
