Shifting numbers in a list (Python3)
Solved by Guest,
1 hour ago, Meic said:Frist to print without brackets use:
print(" ".join(lst))The to shift the other direction (you were almost there)
def shift_right(lst, n): return lst[-n:]+lst[:-n]Rather than passing the newlst to shift, I would recommend:
newlst = shift(lst, n)
Solution provided by @Meic
Note, the first code provided has been changed to make it work for my case, from:
to:
print(" ".join(map(str, lst)))
